205 gti overheating ??
Results 1 to 23 of 23
    brisbane
    2,882
    Default 205 gti overheating ??
    The guy down the road asked me what could be wrong with his 205 as he showed me the header tank actually bubbling and making a hell of a racket. Now i know its been hot in Brisbane so we took her for a run....normal speeds at 80kph on a 33C Degree day made the header tank behave like a kettle... i am stuffed to think what it could be as......
    1. new radiator
    2. new coolant
    3. new w/pump
    4. new thermostat
    Temp gauge shows only slightly over normal.
    Fans work fine.
    Any other ideas i have not thought of?
    jr20516v
    Now:
    Exige SC [modded], 205 Si. Opel OPC
    Previous: Honda EP3 Supercharged , 205 x34 [ including MI16 TURBO, 8v TURBO, CTI, 16V+TB's, 8V+TB's,] Fiat X1-9 X3, Beta coupes x5, Lancia Gamma coupe, GTI-R, Corvette C4, Fiero x5, Alpine GTA turbo, r5 GTT Dimma, 2cv ripple nose, Lotus Elise, 205 Dimma TT, Cliosport 172.x2, Clio rs 200
    1000+ Posts FIVEDOOR's Avatar
    Jun 2011
    Brisbane Qld
    19,837
    Bubbling and temp normal, could it be pushing air?? Dont know if that's possible but just looking at symptoms?
    Every day is a good day
    Mar 2003
    Location Location
    1,571
    5. Header tank cap ok?
    6. No hoses blocked?
    Dec 2010
    Bungendore NSW
    486
    Had this problem with a 407 and it was that the two fans were not kicking in when they should have, One needed replacing and it cured the overheating problem.
    1000+ Posts gezza's Avatar
    Bunbury
    2,191
    Get a low temp fan switch...
    1990 Renault 5 GT turbo
    ####current rides####
    1994 205 gti 1.9 sorento green
    1988 205 gti 1.9 uk import grey
    2001 clio 172 sport ph1 #44/85
    1998 306 gti6. Blaze yellow
    1992 Honda Fireblade
    2013 Yamaha fzs sho Jetski
    1998 Supra RZ twin turbo white
    1999 Wrx classic gc8 sonic blue
    10,679
    Head gasket? Corrosion? Pressure cap?
    I'd start with Flash Car 76's suggestion. Run the car at idle to faster engine speed and check at what temperatures the fans come on - consider using one of those infra-red temperature sensor guns to see what the head and hose temperatures are, and the different parts of the radiator. If it is boiling with coolant, it is well over 100 degrees.
    Last time I couldn't fix a problem like this it turned out to be a very small head gasket leak.
    Be interested to hear the outcome, that is for sure.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    brisbane
    2,882
    Thx guys....will relay those tips to him. Happy New Year too :}
    jr20516v
    Now:
    COL
    COL is online now
    A110 COL's Avatar
    Van Diemen's Land
    3,933
    My worth as i'm not familiar with the 205.
    I see a new thermostat has been fitted, is it the correct one (eg is it the type that has a small hole and if so is the hole to the top?)
    Also is the thermostat been fitted the correct way round.
    I would also remove the thermostat and test it on the stove with a thermometer to make sure that it is working properly.
    Last of all make sure you have bled the air out of the cooling system.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    Armidale
    2,279
    Quote Originally Posted by jr20516v View Post
    ...header tank actually bubbling...
    Fans work fine.
    I'm with JohnW - this sounds like a head gasket leak. Only other thought is radiator/expansion tank cap has failed - even found an old thread on the topic!
    205gti radiator cap or exp. pressure cap?
    Alec
    brisbane
    2,882
    Yes Col...correct thermostat.
    Thx Alec for that thread....we didnt even think about the header tank cap.........will change that as a precess of elimination.
    Also.......hows this for weird...........when driving around at say 60kph the gauge takes 5 mins to go over normal however when we just run the car sitting in the garage [waiting for the fans to come on ] she takes 10-15 minutes. LOL
    jr20516v
    Now:
    COL
    COL is online now
    A110 COL's Avatar
    Van Diemen's Land
    3,933
    Quote Originally Posted by jr20516v;
    I would say that would be right for just about every car.
    An engine idling is not under load, where as driving around it is depending on terrain etc there for will warm up quicker.
    Regards Col
    1973 Alpine A110
    brisbane
    2,882
    I hearwhat you say Col. A closed garage with no free air and probably 36c is a close second though ;]
    jr20516v
    Now:
    brisbane
    2,882
    UPDATE: He replaced the header tank cap. [the existing one wasnt a recovery type cap ] and she is now all good. No tea kettle in the header tank LOL
    But now he has another problem........ the car kicks like a mule when driving. Doesnt matter where....uphill, downhill or on straights. I am thinking maybe fuel related?? Your thoughts ?
    jr20516v
    Now:
    Fellow Frogger! flock's Avatar
    Feb 2014
    Brisbane, Australia
    182
    I had that issue to with crazy bunny hopping. Check to make sure the 2 pin cable from the side of the dizzy is plugged in and not broken/shorted. Mine was doing this as the wire kept shorting randomly and eventually stalled the car.
    Also check connections on ignition coil, mine were loose on that too.
    Sent from my E6653 using aussiefrogs mobile app
    brisbane
    2,882
    I will get him to check that...ta :} Its not like bunny hopping but more a mule kick as he is simply driving along especially when coming off the accelerator then back on....she then will kick for just one second. Sometimes it can kick every say 100 metres at any speed.:[ Mmmmm.
    jr20516v
    Now:
    10,679
    Good!! I presume that means the cylinder head coolant temperatures run above coolant's boiling point at atmospheric pressure? When I tested the Peugeot coolant (the hard way...) it boiled at about 107 degrees in a non-pressurised system. What is the gauge showing and where is the sensor located on the 205 I wonder?
    Renault 4CV 1951
    Renault R8 1965
    brisbane
    2,882
    205 gauges are normally unreliable however it is showing just above normal. Sensor is located just under the dizzy area.
    jr20516v
    Now:
    10,679
    Ah. Does it attach to the head, and measure metal temperature, or is it in the coolant stream - presumably where the hot coolant comes out of the head? If the temperature is normal, i.e. well below 100 degrees, why would it boil without a pressure cap on the expansion chamber. Just puzzled, not arguing or anything!
    Renault 4CV 1951
    Renault R8 1965
    8,777
    Yeah, the sensor is in the exhaust coolant stream, so in theory it measures exhaust temperature, which is the hot side, but apart from the sensor and gauge being far from ideal, I expect trapped air would impact readings as well. If the sensor is not full immersed in coolant it won't indicate anything abnormal hence I would discard any readings unless I knew the system was completely air free.
    ACHTUNG ALLES LOOKENPEEPERS
    10,679
    Hmm. I don't disagree at all, but if there were that much air in the system, would it cool?
    Boiling like a kettle, add pressure cap and it doesn't?
    There's something there I don't get.....
    Renault 4CV 1951
    Renault R8 1965
    Armidale
    2,279
    So might still have a small head gasket leak?
    8,777
    Good question.
    By that I mean I don't have an answer I can back with experimental proof.
    In principle it would cool as long as the coolant can still circulate to the radiator and back. Even if it didn't, you still need to keep adding heat to coolant to keep it boiling (until it's all gone anyway). The exhaust manifold (and the head, at least on the exhaust side) is way above 100 deg C hence it is above the water boiling point. Hence water still absorbs heat from the head, etc., which is to say it is still cooling the engine (to some degree).
    To make this more complicated you could try to think of the water vapour pressure and how that affects the boiling point. A small pocket of air will be vapour saturated very quickly and reach high pressure faster (than a large air pocket) hence providing some negative feedback (reducing water evaporation) and causing the water boiling point to raise again a little bit.
    The coolant reservoir cap has a set release pressure (above atmospheric) by construction (spring loaded seal), but it needs to seal to function (i.e. to release only when that pressure is achieved). The pressure inside the system therefore will build to that point, which will serve to raise the coolant boiling point (alongside the chemistry of the coolant).
    You would have learnt at uni about decompression (retrograde) boiling, which explains some of the violent volcanic eruptions in volatile rich lavas (acidic, i.e. rhyolites to some if not all andesites) in contrast to water poor lavas (basic - basalts). Same mechanism here.
    8,777
    I would call that a possibility not eliminated yet.
