Getting a stick out of a petrol tank.
Results 1 to 25 of 27
Like Tree32Likes
Thread: Getting a stick out of a petrol tank.
    16,295
    Default Getting a stick out of a petrol tank.
    Hi Guys,
    I know a genius .... who doesn't need to be named that dipped the petrol tank on the tractor too see if there was enough fuel in it to cut the grass..... and managed to drop the stick I can see it down there with a torch floating happily. I'm not really keen on it breaking up and making a mess of the fuel system. Surely there is other poeple out there as stupid as ... er ... "this person" so have a smart way of retrieving the stick.
    The simplest way I can think of it to just fill the tank ... It will sit there floating at the top for me to grab with two fingers .... So I looked at the specs. The damn tank hold 80litres I don't have enough $$$ to spare to fill it (not to mention filling it 20litres at a time from a drum is bloody hard work!).
    1000+ Posts okalford's Avatar
    Sep 2004
    10,880
    Hi Shane, you could probably get it out with one of those claw ended grabber things. I have one that I think I got from a $2 shop. Will post a pic if I can find it. They are quite handy cause they fit into small spaces and can pick up little things.
    Kaye
    ETA pics and details. This is it, about 50 cm long which might be too short? Little claws open to about 17 mm.
    Getting a stick out of a petrol tank.-claw-thing-1.jpg Getting a stick out of a petrol tank.-claw-thing-2.jpg
    Roland, IWS, Fordman and 1 others like this.
    '66 404 Wagon
    '78 504 Wagon
    '89 505 GTI S II Familiale
    COL
    COL is online now
    A110 COL's Avatar
    Van Diemen's Land
    3,933
    Make a lasso out of some tube (eg conduit) and wire.
    Fold the wire in half and feed wire down the tube so there is a loop sticking out the one end. where the two ends come out of the tube these are what you pull after you have put the loop end into the tank and hooked the loop over the stick.
    Good luck with it.
    Roland, okalford and David S like this.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    7,416
    Drain it, fill it with water, get the stick out, drain it, etc.
    FIVEDOOR, Roland and JohnW like this.
    8,537
    You'd be surprised what can be retrieved from a pipe or well with one of these. Make one from wire and try it. Getting a stick out of a petrol tank.-pipe-retriever.jpg
    okalford likes this.
    1000+ Posts Beano's Avatar
    3,001
    Dear Fathead,
    Get a long thin piece of wood, create some loose bands in it with wire, and run a piece of thin wire up it, under the bands, ending in a loop at the end. Slip the loop over one end of the stick and pull the end to tighten it.
    Do the operation at night, holding a very bright torch in your mouth.
    OOPS.... just noticed that Col suggested the same thing.
    OK...my contribution....do it at night. You'll have much better success.
    18,477
    At night at least your stupidity won't be noticed.
    IWS and bluey504 like this.
    1000+ Posts Fordman's Avatar
    May 2004
    Perth/West Australia
    1,358
    I have a similar claw device as Kaye - been used many times and very useful. A few dollars in an auto shop.
    2004 Scenic I 2.0 auto (Hers)
    2016 Ford Territory (His)
    2004 WRX (Sunday car)
    BVH Roger Wilkinson's Avatar
    Warrnambool
    2,295
    Diesel won't harm the stick as much as petrol, I reckon.
    Roger
    BIGRR likes this.
    9,631
    Can you charm it out, snakewise, with a magic flute?
    Or, park it on a slope, so the fuel flows to the end with the filler.
    4,352
    You could toss a match in to burn the wood thereby not having to pick it out? Again best done at night.
    IWS, pug206gti, driven and 6 others like this.
    KB
    Mar 2011
    Linton.Victoria.
    1,189
    Smither Reens...is his name
    Sent from my HUAWEI TAG-L22 using aussiefrogs mobile app
    SWOTR
    3,443
    Ignore the wood and keep on motoring.
    1000+ Posts Kim Luck's Avatar
    Melbourne, Aus.
    17,684
    How about "Fetch, Rover"?
    Fellow Frogger! Roland's Avatar
    Perth
    726
    Quote Originally Posted by Beano View Post
    . . . holding a very bright torch in your mouth. . . . .
    What if he coughs in the middle and drops the torch in the tank as well?
    Roland
    JohnW, IWS and J-man like this.
    Land Rover Discovery 4
    406 Coupe D9 - Manual (2002)
    307 Hdi Estate - Auto - (2007)
    307 Hdi Sedan - Auto - (2007)
    505GR Estate - Personal Import from UK 1971cc Manual (March 1986)
    405 Mi16x4 (all the parts ready to install into the LeMans body)
    CitroŽn Tragic UFO's Avatar
    9,649
    Video or it didn't happen.
    Mar 2013
    olinda victoria australia
    671
    You learned this using a snare for crays?
    Naughty boy
    Andrew
    8,777
    Quote Originally Posted by Roland View Post
    Roland
    Crackpot!
    That's okay, he'll see a lot better where the stick was.
    ACHTUNG ALLES LOOKENPEEPERS
    9,631
    or if he swallows the torch, the light shining from inside him will just be a bit brighter.
    10,679
    Good luck with it.
    Agree good idea but very cruel suggestion. You KNOW it'll always lassoo successfully but with just too long a 'short' bit beyond the wire to pull it out....
    Wood in petrol? Might it last forever without decay? Cork floats go for decades.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    SWOTR
    3,443
    Even if the wood rots away the fuel filter should catch debris?
    Fellow Frogger! denxm's Avatar
    uki aust
    447
    When you fish the wood out,grab a length of yellow tongue off some ply flooring sheets,make great dippers.
    Audio installers also use it to run wiring under headlining etc.
    9,631
    ... You KNOW it'll always lassoo successfully but with just too long a 'short' bit beyond the wire to pull it out.... . ...
    Just like the classic monkey trying to get the nut out of the bottle problem.
    JohnW likes this.
    It's how I roll...Brisbane
    32,802
    Quote Originally Posted by denxm View Post
    When I was a young chippy working on site I used to hate bloody electricians pinching the yellow tongue as soon as your back was turned, we'd be trying to finish off a floor with half a dozen yellow tongues missing..
    May 2004
    1,358
    Shane:
    a) Surely you have got it out by now! Good suggestions above.
    b) If not, you could just leave it in there to be dissolved, call it bio fuel.
    c) If you don't like the idea of putting water in to raise the level, try filling the tank with small rocks until the fuel level rises enough to reach the stick (as per the clever magpie video).
    d) Get a longer stick for next time!
    Regards
    Chris.
    David S likes this.
