XU9 Mi16 - Full Rebuild
Results 1 to 22 of 22
Like Tree6Likes
  • 1 Post By pug-life
  • 1 Post By pgti6
  • 2 Post By GRAHAM WALLIS
  • 1 Post By GRAHAM WALLIS
Thread: XU9 Mi16 - Full Rebuild
    1000+ Posts pug-life's Avatar
    Geelong
    1,226
    Default XU9 Mi16 - Full Rebuild
    Hey Froggers,
    So, my 1993 Miami Blue 205 GTi currently has an Mi16 in it. It never ran very well even after extensive investigations to get it running right. That's neither here no there now.
    The plan now is to build up another Mi16 and replace it. Looking for around 190BHP - 200 (if possible).
    Can you please suggest who might be the best person to approach that can do it from start to finish?
    If's its you, put your hand up.
    North Geelong Engine Reconditioners down here (Vic) are well known for their work, but I would have to walk them through what I want
    XU9 Mi16 - Full Rebuild-img_0568.jpgOpen to suggestions, lessons learnt, limiting factors, feedback.
    The want/desired list would probably include:
    • Forged pistons (Brand?)
    • Tunable ECU (Brand? Emerald, Haltech?)
    • Cams (taylor, cat cams?)
    • Coil packs (spec ?)
    • Baffled sump (GTi6 good enough, or modified XU9?)
    • GTI6 intake manifold.
    • Throttle body (GTi6 standard or modify for larger one?)
    • Any mod that would improve oil pickup and distribution (open to suggestions)
    • injectors (GTI6, XU9 stanard, other?)
    Thanks everyone.
    Look forward to hearing your advice & feedback.
    Julian
    SilverGTi_6 likes this.
    Jan 2011
    Traralgon
    642
    $$$$$ is the real limiting factor. What do you think you want to spend?
    Biggest bang for buck is all about head and compression. Probably don't need significantly bigger valves, but you do need compression.
    After that, get onto some quad throttle bodies - they make a big difference, but cost a lot.
    For ECU - personal choice. I'd say Haltech, and Peter Taylor can help you out there.
    Decide your budget and then others may have specific recommendations. If Graham Wallis still has the head of the engine that split a liner - buy it!
    racing 405
    1:59:09 last time at Phillip Island - less than standard Mi16.
    Ipswich, Queensland.
    1,873
    Maybe do a deal with Peter Taylor, if he can find the time and is interested.
    '56 Renault 750 (16TS Power)
    '62 Renault Dauphine Gordini
    '08 Renault Megane sedan
    1000+ Posts pgti6's Avatar
    May 2001
    1,602
    Hey Julian,
    I've got an Mi16 block just removed from my race car-
    forged pistons, peened rods, ARP bolts, TTV 3.9kg flywheel, 11.5:1 CR, 1927cc. Also have baffled sump, windage tray, extended pick up & XU10 pump available.
    It could be a good start to your high performance engine.
    Jeff
    Roland likes this.
    Lap times-
    Sandown 1 27.9
    Phillip Island 1 53.8
    Previous Frenchies-
    1988 205Gti
    1998 306 GTi6
    1997 306 N5 sedan
    1996 306 N3 XT hatch
    9,103
    Head went to Parry. Present motor has 10.5 to 1 D6C pistons, Jenveys, Megasquirt 3, Constella baffled sump, that's it. It has 143 hp at wheels about what you are looking for and is going great at Adelaide Rally, climbed the Collingrove Hillclimb very well yesterday.
    CEyssens and Codman like this.
    Geelong
    1,226
    Hi gents. Thanks for the replies. I guess I was think I wasnt going to get much change from $3500-$4000 if some properly (before ITBs).
    Jeff, long time no speak. Is that from your 405? Was that an alloy or iron block? Does your mobile still end in 430?
    Graham, Is that your setup in the 309?
    But yes this is down the path Id like to go. Perhaps not ITBs at this stage. Well see...
    Ill contact you all individually to discuss
    May 2001
    1,602
    Quote Originally Posted by pug-life View Post
    Yes, alloy, yes.
    Lap times-
    Sandown 1 27.9
    Previous Frenchies-
    1988 205Gti
    1998 306 GTi6
    1997 306 N5 sedan
    9,103
    Yes, 309.
    Hi gents. Thanks for the replies. I guess I was think I wasn’t going to get much change from $3500-$4000 if some properly (before ITB’s).
    But yes this is down the path I’d like to go. Perhaps not ITB’s at this stage. We’ll see...
    I’ll contact you all individually to discuss
    7,414
    I think you should buy Jeff's bottom end. Anyone can say they can rebuild an XU9J4 but in reality, very few have the experience necessary in Australia. The head is relatively straight forward. The block however has two main stumbling blocks.
    One. The liners warp easily if they're not clamped down whilst boring/honing.
    Two. The original pistons centre the rod on the crank pin. The 8V in comparison has a wider rod and is centred in a more conventional way on the crank pin. I don't know of any aftermarket XU9J4 pistons which centre the rod correctly. If using XU9J4 rods, the piston needs to be machined internally to create parallel thrust faces and washers made. The alternate option is to use 8V rods and fit bronze bushes to the little ends. Should you not address this problem, the rod will flog about on the pin and eventually crack the piston bosses.
    Attached Thumbnails Attached Thumbnails XU9 Mi16 - Full Rebuild-iapel-thrust-washers.jpg
    Geelong
    1,226
    Thanks Peter.
    And these are the exact reasons why I was apprehensive to have a a local business (as good as they may be) to do the work on an engine like this.
    If you had the choice between doing the same build to an XU9J4 & and XU10J4RS, which in your opinion is the better platform ?
    Fellow Frogger! SilverGTi_6's Avatar
    Apr 2005
    836
    I can't add anything useful, but best of luck with the build mate! Look forward to seeing the progress.
    Lotus Evora
    Peugeot 308 GTi
    1966 Volvo 122s
    Clio Sport Cup 182
    Previous
    Lotus Sport 111, C4 VTS, RCZ, 205 GTi, Volvo C30 T5-R, Honda S2000, 206 GTi180, Lotus Elise 111R, 205 GTi 6, Manual 406 coupe, 306 GTi 6, 405 MI16 (twice!), 505 GR
    7,414
    The RS is obviously more powerful, more reliable and cheaper to rebuild. However, if you want to retain that light, crisp feel without spending heaps on suspension, then XU9J4. It really just comes down to the + and - of each.
    Oct 2003
    613
    Is it too much to put my hand up?
    • Forged pistons Email Pug1off & see what they can offer. Just because they dont have it listed on their website doesn't mean they can't offer a solution. I would get a piston & rod combo rather than just pistons. That way you don't have to faff around with centering.
    • Tunable ECU A LOCALLY supported ECU! Tech support is a phone call away. MoTeC M84 or M130 (both incredibly powerful & easy to tune), Haltech Elite 1000 or PS1000 (Simple to understand, use & tune.Tech support is excellent), Link (NZ), Vipec (Link ECU, different software), Autronic, Adaptronic..... Personally I would stay away from Microtech.
    • Cams Peter's cam's all day everyday.
    • Coil packs Bosch 0980AG0700 coils & quad channel igniter. Alternatively, If a XU10 cam cover will fit, XU10 coils with quad channel igniter, (seems a bit of a step backward loosing the nice magnesium cam cover though.)
    • Baffled sump GTi6 sump & pump
    • GTI6 intake manifold or XU10 dual runner intake. XU9 intake is junk compared to these two
    • Throttle body (GTi6 standard or modify for larger one?)Don't modify the GTi6 63mm throttle body unless you want to go backwards. It is spherically machined to make it progessive. The 55mm XU10J4 throttle body is adequate for 200hp.
    • Any mod that would improve oil pickup and distribution As before, 2L oil pump
    • injectors Standard yellow injectors should be adquate. Others to look at would be the 240cc XU10J2TE, 260cc GTi6 with matching fuel rail or Supercharged Commodore 370cc with a retaining clip groove machined
    Even if you go for pistons, rods & a modified oil system, you're still dealing with the bad oil gallery routing of the 88mm cranks and a cylinder head with poor oil drainage. The RS motor takes care of both of these issues. Find a decent RS motor, throw a set of Peter's Stage 1 cams & a good aftermarket ECU at it and it will make close to 200hp straight up. Dollar for dollar, the RS motor wins everytime. Jeff's bottom end still looks like a good option though.
    Geelong
    1,226
    Hi Bluey,
    Great information mate, thanks for that. Nope, i was anticipating you stepping into the ring I just couldn't remember your forum name.
    This is was the other dilemma i was facing. I currently have GTi6 engine with 160k's on it just sitting in the shed...but was leaning towards keeping with the era of engine (Mi16) which I also have access to. Those HP figures sound about what i was hoping to achieve.
    As Peter mentioned, there are + and -'s for each. I've experienced both engines in the OEM condition & I could be swayed either way TBH.
    Either way, this will be the thread where I show the progress of the build.
    1000+ Posts gezza's Avatar
    Bunbury
    2,191
    I have a complete gti6 head here with intake injectors etc
    1990 Renault 5 GT turbo
    ####current rides####
    1994 205 gti 1.9 sorento green
    1988 205 gti 1.9 uk import grey
    2001 clio 172 sport ph1 #44/85
    1998 306 gti6. Blaze yellow
    1992 Honda Fireblade
    2013 Yamaha fzs sho Jetski
    1998 Supra RZ twin turbo white
    1999 Wrx classic gc8 sonic blue
    Geelong
    1,226
    Quote Originally Posted by gezza View Post
    Hey Gezza, long time no speak. Ive got a complete one in my shed. But thanks anyway mate. Hope alls well out west.
    gezza likes this.
    May 2001
    1,602
    My plan was to re-fresh the alloy block, re-fit the wet sump set up and a J4RS head and manifolds all of which I have.
    The extra compression and deeper valve pockets would allow for bigger cams. Run that on aftermarket engine management in a 205 and I reckon it would easily out perform a standard 205 GTi6.
    Problem is finding a clean, restorable 205 at a reasonable price seems now passed.
    Lap times-
    Sandown 1 27.9
    Previous Frenchies-
    1988 205Gti
    1998 306 GTi6
    1997 306 N5 sedan
    Oct 2003
    613
    Jeff's engine keeps sounding better & better. At the end of the day, YOU have to be happy with what you're driving. If that means going with the XU9 then go for it.
    7,414
    Jeff's engine is well sorted. I'm fairly sure I designed the pistons and the liners were done at Bakers in Orange. All you'd need to do is drop a head on it. I have another set of pistons & liners here from the same batch if you want some pics.
    9,103
    I have a Miami S3, not expensive, straight and running well but needs paint. May be available depending on whether my standard 309 GTi sells to an interested party.
    Quote Originally Posted by pgti6 View Post
    1000+ Posts Richard W's Avatar
    May 2012
    1,338
    Stand by to be knocked down in the rush Graham. I'm struggling to stop myself from enquiring and making an offer!
    In the current market, would one be better to put the 16v in an good Si and re-do the Miami standard? Though a hot 16V Miami would be uber cool and fun...
    Sent from my BBB100-1 using Tapatalk
    9,103
    Yes, a few have got in touch.
    The car is probably valued at $2500. It is fairly rough, it needs a bonnet, grey one supplied, front under bumper plastic, red one supplied and a bit of work on the hatch. Tyres are near new (3) one OK. Runs fine, has new fuel pump, as I found the original had died when the car was rescued recently. Has Bilstein Challenge front struts that I fitted 3 years ago, beam is probably OK, needs master cylinder, I would fit this, interior needs seat repairs otherwise good but a bit grubby, dash top perfect. Exterior plastic 99% OK, bumpers fair, needs windscreen and headlights. In original condition. Originally from Tasmania. No sunroof.
    Best to come and take a look in Dandenong.
    michael_ozzie likes this.
