Wheel rim offset - what is "margin for error"?
    Armidale
    2,279
    Default Wheel rim offset - what is "margin for error"?
    Is there a rule of thumb (eg. a percentage) for how much variation in wheel rim offset is OK? I presume that increasing positive offset increases overall track - this presumably increases stress on suspension. Does too much offset also increase risk of tyres rubbing on wheel arches?
    I am in the market for 16" rims, which I will fit to either a 406 or a Xantia, depending on which one's registered etc. - these cars have virtually identical wheel requirements, with offset varying between ET12 & ET20 depending on width & .
    Now according to wheel-size.com a number of PSA models were/are fitted with 16" rims with the correct PCD (4x108), but all seem to have a larger offset - the lowest being 25 or 26 for the C5. I've got no idea whther this might cause problems...
    Alec
    7,414
    Increasing positive offset decreases overall the track. The wheel/tyre will be closer to the strut tower.
    Decreasing offset increases track.
    +/- 6mm from the original is usually fine. I'd be looking for less offset rather than more. Changes to suspension, scrub radius etc. are really insignificant at that level.
    Armidale
    2,279
    Ahh - thanks Peter - obviously I had it back to front!
    I wasn't planning on increasing offset - I'm just trying to understand which models might have compatible wheels.
    The +/- 6mm should be very helpful - with that as a guide, some C5 rims should be OK.
    Jun 2011
    Tasmania, Australia
    210
    Default Pug Alloy wheel chart
    Alec
    Hi Alec
    A handy wheel selector chart here. Citroen have similar lists
    Original Peugeot Wheels
    Allen
    brisbane
    2,882
    Also can use 1010 tyres site to show you what the tolerances are inside and out.
    jr20516v
    Now:
    Exige SC [modded], 205 Si. Opel OPC
    Previous: Honda EP3 Supercharged , 205 x34 [ including MI16 TURBO, 8v TURBO, CTI, 16V+TB's, 8V+TB's,] Fiat X1-9 X3, Beta coupes x5, Lancia Gamma coupe, GTI-R, Corvette C4, Fiero x5, Alpine GTA turbo, r5 GTT Dimma, 2cv ripple nose, Lotus Elise, 205 Dimma TT, Cliosport 172.x2, Clio rs 200
