807 engine balance.
Results 1 to 11 of 11
Like Tree5Likes
  • 1 Post By Bustamif
  • 1 Post By PeterT
  • 1 Post By alan moore
  • 1 Post By 59 Floride
  • 1 Post By Shoji
Thread: 807 engine balance.
    482
    Default 807 engine balance.
    Can 807 gurus please comment.
    I have a few periods of vibration in my engine.
    Mild at 2000, harsher at 3100.
    Yes I made my engine brackets and everything else is modded to the max etc etc. I admit there is more parts on it than in the space shuttle.
    My pistons, wrist pins and rods were all within a gram.
    I didn't balance the crank balanced because 2 I got checked in the past were good from the factory.
    I'm using a different flywheel than the one that came with this crank.
    Did the factory balance as a set?
    I didn't balance the flywheel or press plate either.
    It's costing me $10 a day in super glue to keep gluing my fillings back in.
    Any 807 guru comments?
    Sent from my E5823 using Tapatalk
    BR
    Building a race car is easy - building a race car that can be road registered is hard.
    For any custom fabrication call Precision One Off Engineering - Sydney 02 4587 8666
    Simon's Avatar
    6,123
    Buffeting as the car just starts hitting the sound barrier?
    Otherwise the crank and fly (along with the clutch) were balanced as a set from the factory.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    Oct 2014
    Windsor 2756 NSW Australia
    561
    Considering the revs you have reached on that motor I would definitely balance the clutch and flywheel as an assembly and not assume the factory spent the time and effort necessary for an engine with your mods. Same goes for the crank. I have seen the result of a wobbly flywheel coming out of a bellhousing on a Porsche then through the rear parcel shelf at 8k rpm (not mine). It may be worth checking to see if the flywheel bolts are all tight, from what I have seen with other people’s engines, if there is a balance problem. the flywheel bolts usually loosen up before letting the flywheel escape.
    Roland likes this.
    7,416
    I concur. The harmonic balancer, crank, flywheel and pressure plate need to be balanced as a set and marked for assembly.
    Roland likes this.
    1000+ Posts driven's Avatar
    Apr 2005
    1,392
    Had issues with rough 807 engine. Maybe not as bad as you have
    After rebuild never put back the two large weights on each side of engine at the front.
    Forget what they were called, DePhasers?
    Refitted with new rubbers and all good.
    Never used a front pulley either, aka R16,
    I recall flywheel only fits one way by bolt hole pattern. Need locktite so they don't come loose. May be loose bolt here
    French would have never balanced the assembly as a whole. They were into saving money!
    Just bolt up the individual balanced components at assembly.
    Pressure plates are balanced by manufacturer. Look closely.
    Always use new bolts on pressure plate. Old ones stretch and break on old Renaults
    Ensure they are all the same with the same washer type
    You can change these bolts one at a time
    Ipswich, Queensland.
    1,874
    The 807 cranks I have had balanced have been very close from the factory. If getting balancing done yourself, the flywheel would then be fitted to the balanced crank, and then the pressure plate and balanced in turn. I don't know what the factory did, but I doubt they would have done this. Given I expect you lightened the flywheel it would have been prudent to have balanced it on your crank.
    Renault went to a lot of trouble on the R15/17 with the 807 motor to fit a large crossmember with "Dephasers" as Driven has mentioned to try and deal with harmonics. I do remember my 15 having a harmonic vibration at 2700 -2900 Rpm. I changed a lot of parts including the engine, fitting a flex section to the exhaust, engine mounts, and so forth and never did get rid of it.
    Roland likes this.
    '56 Renault 750 (16TS Power)
    '62 Renault Dauphine Gordini
    '08 Renault Megane sedan
    1000+ Posts Shoji's Avatar
    Jan 2012
    Mandurah WA
    1,057
    Very interesting reading.
    Geko Engineering had picked up on a drive, that my 17 maybe has this similar issue. At around 3000rpm it has a vibration. Ray mentioned harmonic balance.
    On the new engine we will be talking balancing.
    Good luck with finding the issue Brett.
    It's how I roll...Brisbane
    32,802
    ...is the family cat accounted for?
    10,679
    Quote Originally Posted by Shoji View Post
    Very interesting reading. Geko Engineering had picked up on a drive, that my 17 maybe has this similar issue. At around 3000rpm it has a vibration. Ray mentioned harmonic balance. On the new engine we will be talking balancing.
    I'd more than talk. When I last did the R8 I had it fully balanced, clutch included. But then you will be doing it, I'm sure.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    Citroën CX Pallas 1980
    Jan 2012
    Mandurah WA
    1,057
    Absolutley JohnW. Fully balanced, got it!
    That includes weighing certain items, yes? Pistons, rods, etc.
    I'm sure Geko Engineering will sort it out for me.
    JohnW likes this.
    8,777
    You don't need to weigh pistons rods, etc, other than making sure they are the same weight, which you can do at home with a kitchen scale (you don't need more precision than .1g). I rebuilt my engine with Bretille pistons from Mecaparts and they were all the exact same weight. Conrods and pins were reused and they were all within the .1 gram accuracy of the scales I used.
    The shop where you take your bits will require a piston, a pin and a conrod to factor them in the balancing exercise (based on the assumption they are all the same weight), together with anything that is bolted to the c'shaft for dynamic balancing.
    ACHTUNG ALLES LOOKENPEEPERS
