ENGINE TIMING TOOL SET - anyone bought this cheap set
Results 1 to 20 of 20
  • 1 Post By dimistyle
Thread: ENGINE TIMING TOOL SET - anyone bought this cheap set
    Aug 2016
    Sunshine Coast, QLD
    848
    Default ENGINE TIMING TOOL SET - anyone bought this cheap set
    https://www.vidaxl.com.au/e/87184758...0aAjAoEALw_wcB
    Just looking at options as have 2 x HDi 2.0 engine cam belts to do at some stage over Xmas break. Should I buy a cheap set like this as bound to have all the locking pins but probably no instructions but that's ok.
    May end up using the French mechanic out at Kenmore QLD as he's also a mobile mechanic.
    Also any belt manufacturer to stay away from as quire a few Euro branded belts are now available in AU.
    Your thoughts....
    8,537
    It's a pity it's listed by cars and not by engines, but all the models listed are currently obsolete. That may explain the outlet and price.
    Fellow Frogger! Roland's Avatar
    Perth
    726
    Morning all,
    The exact same kit is on Ebay at nearly twice the cost.
    ENGINE TIMING TOOL SET (CITROEN & PEUGEOT) GAS/DIESEL BELT CHANGE NEW (15-43) | eBay
    I have 2 x 307 2.0Ltr Hdi vehicles to change the cam belt on soon, (overdue in fact) so I have ordered one of these kits.
    So thanks Dimistyle for finding this kit at a very good price.
    It looks like it has all the pins and flywheel locking jigs one would need for any job and my engines and cars are all listed.
    One of those lengthy right angle shaped pieces of steel has got to be the one to slip in behind the starter motor and through the hole in the block to lock the flywheel. And that alone is worth the money!
    Roland
    Land Rover Discovery 4
    406 Coupe D9 - Manual (2002)
    307 Hdi Estate - Auto - (2007)
    307 Hdi Sedan - Auto - (2007)
    505GR Estate - Personal Import from UK 1971cc Manual (March 1986)
    405 Mi16x4 (all the parts ready to install into the LeMans body)
    Aug 2016
    Sunshine Coast, QLD
    848
    Quote Originally Posted by Roland View Post
    Morning all,
    It looks like it has all the pins and flywheel locking jigs one would need for any job and my engines and cars are listed.
    Roland
    Roland have you decided which timing belt kit your going to buy?
    These are at a good price atm and I had them correct the engine to the 8v HDi not 16v as it was listed.
    Now for the waterpumps..
    http://www.ebay.com.au/itm/151129271969
    Armidale
    2,279
    Can anyone comment on whether it is worthwhile paying extra for an HSN (Highly Saturated Nitrile) timing belt, and whether it is safe to extend the belt change interval with an HSN belt fitted?
    Alec
    16,295
    hmmm... I wonder if this kit would work on the 407 2.0 HDi I have here (wihotu remove the engine from the vehicle to use it too). I have a cambelt to change ... and probably shoudl do the clutch at some point.
    Aug 2016
    Sunshine Coast, QLD
    848
    Alec
    Alec we used kevlar belts on scooters and they were the bee knees to extend the replacement interval but manly used to reduce slipping as less stretch. HSN sounds interesting
    Perth
    726
    . . . I wonder if this kit would work on the 407 2.0 HDi I have here . . .
    Hi Shane,
    Your engine would be basically the same as for my engines in my 2.0ltr Hdi 307s (16 valve - 2007) wouldn't it?
    So I can't see why the same kit wouldn't work for you!
    Roland
    Perth
    726
    Quote Originally Posted by dimistyle View Post
    Roland, have you decided which timing belt kit your going to buy? . . .
    [/URL]
    No, not yet.
    I'll probably do that closer to Christmas time when I do the changeover.
    Roland
    8,537
    I think you ought to compare the photos with a brand that does tell you which engines it suits. Here is a page from a Sealey catalogue.
    Sep 2003
    North Parramatta
    3,986
    Looks like a nice kit - suitable for HDi and petrol EW motors, at least.
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    Aug 2016
    Sunshine Coast, QLD
    848
    Thanks Seasink, I downloaded their pdf to check the tools required and all included for RHY and RHZ diesels. The kit is missing one tensioner locking pin for the petrol engines so buyer beware.
    Dimi
    Roland likes this.
    Aug 2016
    Sunshine Coast, QLD
    848
    Morning all,
    Roland
    Roland has the timing kit arrive, what is the quality like?
    Post s pic or 2 as interesting in buying a set.
    Cheers, Dimi
    Oct 2017
    29 Elliot Road, Dandenong South, Victoria 3175
    2
    Every car owner should very well know that not all parts of his car will last forever. Though not all of it are consumables, most parts of it will have to be replaced at some point. So if that time comes when a part of your car is broken or worn out and needs to be replaced, one decision needs to be made. Or simply, you’re gonna have to answer the question: What kind of car part are you going to buy?
    Perth
    726
    Cheers, Dimi
    Hi Dimi,
    Yes the kit has arrived.
    Quality looks good.
    It's the same as all the retailer's pictures show.
    The plastic case is good.
    I also took the opportunity to buy:
    https://www.vidaxl.com.au/catalogsea...sult/?q=210292
    They are over 6m in length so now I can jump start my flat battery cars from the next suburb instead of pushing them around to get close enough so cables can reach!
    Roland
    Aug 2016
    Sunshine Coast, QLD
    848
    6m is a good jumper lead length would come in handy when you have park behind someone to jump start. Hope they can handle the current!
    Member davo8's Avatar
    NSW
    70
    I would like to see a set of tools suitable for the SV 3 litre V6 petrol engine. Nothing world wide when I last looked.
    Aug 2016
    Sunshine Coast, QLD
    848
    https://ozwidetools.com.au./products/dm-3454-peu
    Not sure id correct V6 engine but these guys stock a kit
    NSW
    70
    Thanks Dimistyle. I will give them a call.
    Looks like it may do the job. I ended up making my own tools last time I changed the belt but the method i used to hold the camshafts was not ideal.
    COL
    COL is online now
    A110 COL's Avatar
    Van Diemen's Land
    3,933
    Quote Originally Posted by davo8 View Post
    I have a similar set of cam belt tools for my Renault Laguna ii (which is a similar engine). I found the tools to be good but the kit did not include the tool to rotate the inlet cam sprocket so I had to manufacture one.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
