Catch can advice
Results 1 to 18 of 18
  • 1 Post By bowie
Thread: Catch can advice
    Fellow Frogger! callipygous's Avatar
    Jan 2006
    Toowoomba
    797
    Default Catch can advice
    I'm looking to install a catch can on my Peugeot 504t. So far, the best for the money that I have found appears to be the Mishimoto can, however it, along with so many of the other cans fails in one department. Namely, the inlet/outlets are about 12 mm diameter, whereas the crankcase breather hose on the 504 engine is 3/4" or ~19 mm. So I'm going to have to look further for a solution.
    Here's my criteria for a can:
    recirculate to intake not vent to atmosphere
    Baffling - very important
    Not sealed - you can take it apart
    cylindrical and the base screws out
    No stupid external sight hoses that could leak
    3/4" inlet/outlet
    No expensive/exclusive filters that can't be cleaned - i.e Flashlube Catch Can with $100-a-pop filter
    $200 absolute max
    So far my internet searches haven't come up with anything suitable, so I was hoping that maybe someone on these forums have come across something that would suit?
    Peugeot 504 Intercooled T04 Turbo.
    4,352
    A lot of 4x4 guys use provent catch cans.
    I use a similar one from forefront industries.
    KB
    Jan 2006
    Toowoomba
    797
    I'm actually looking at Provent style catch cans right now. Looks as if it may suit my application. Seems there are lots of different vendors for the Provent, and a lot are possibly copies? Is there anything to watch out for when buying one?
    4,352
    Have a look for the forefront ones on his page. That's what I used. Good value for money.
    Meets most of your requirements except the top comes off rather than the base.
    KB
    Jan 2006
    Toowoomba
    797
    The only thing I don't like about them is they aren't a 'catch can'. They require the oil to be returned to the sump.
    4,352
    Or run a tube down to the wheel arch with a stopper and empty occasionally as required?
    KB
    Fellow Frogger! ducksonetime's Avatar
    164
    If recircling to intake, I've seen a lot of people use in-line oil separators for air compressors. Seems to work pretty damn well.
    The colour of this guy's oil doesn't look too good, but look it up, peoples swear by it and it's heaps cheaper than a catch can. The only issue is apparently catch cans need to have a 2 litre capacity according to CAMS regs.
    Current rides:
    '99 Honda VFR800 (daily)
    '02 Ducati 998 (weekender)
    Current Project:
    405 Mi16 2.045L
    http://goo.gl/ha5jLL
    Past rides:
    156 GTA
    https://youtu.be/HmKwwCwGrVg
    https://youtu.be/y-kgE4HyWzk
    306 GTi6
    405 Mi16
    Series 5 RX-7 TurboII
    E30 325i
    Jan 2006
    Toowoomba
    797
    Yeah but running a plugged hose down inside the fender defeats the purpose of a catch can...
    With the air compressor filters - I found a whole bunch of how tos but they all use 3/8" pipes. Way to small - need 3/4".
    901
    How about this:
    Racetronix - Catch Tank, Single -10AN, Black
    with 2x Racetronix - Adapter, -10 ORB Male»-12AN Male, AL BK
    and 2x Speedflow Australia - Hose Ends 400 series barb to -12AN (401-12 or 403-12)
    That seems to fit most of your needs, but only has -10 (5/8") inlet and outlet with o-ring sealing, so needs an adapter to get it up to -12 (3/4"). The speedflow barb fittings are not the cheap option, but there's a few places including autobarn sell similar fittings.
    If you could find a -10 o-ring to -12 barb that would maybe work well?
    1984 505 Executive Auto
    206 GTi 180 - '804 Cat Cams, Jenvey DBW 48mm ITB's, Emtron KV8 ECU, HP Electronik PDM, AIM MXS Dash, Custom Wiring Harness. AST Camber Tops & Coilovers, -2deg camber hubs by Frogstomp Racing, 24mm Torsion Bars, AP Racing brakes, PeugeotSport Baffled Sump, Oil cooler, Quaife LSD, E85.
    Sandown - 1:31.5
    Winton - 1:40.2
    Wakefield - 1:13.5
    Phillip Island - 1:55.9
    Previously, 2x 504 Wagon, 505 Wagon, 505 STi, 405.
    8,372
    Quote Originally Posted by ducksonetime View Post
    The colour of this guy's oil doesn't look too good.....
    That looks like fairly typical sump snot.
    Gets a whole lot worse running e 85.
    Jan 2006
    Toowoomba
    797
    Quote Originally Posted by speaksgeek View Post
    I want to avoid stepping down (using adaptors) from 3/4". I'm sure some R&D went in to making the breather on these engines that size.
    901
    You've got a very tough set of requirements then.
    Sandown - 1:31.5
    Winton - 1:40.2
    Wakefield - 1:13.5
    1000+ Posts bowie's Avatar
    Aug 2002
    Sydney, Concord City, Sir.
    3,318
    I bought one of these
    Billet Aluminum Car Racing Engine Oil Catch Tank Can Reservoir Red Round + Hose | eBay
    Was about $10 i think.
    It comes apart completely (I stuffed mine with steel wool) and has fittings that are removable for what ever gauge hose you want.
    Hasn't leaked, would recommend. Did your 504 have a charcoal canister? Re-purpose that?
    PeterT likes this.
    7,414
    $26 for all that! Very hard to beat.
    Jan 2006
    Toowoomba
    797
    Haha, I know! I think I'll end up making my own at this rate...
    Jan 2006
    Toowoomba
    797
    Never came with one, mine was a '74 so pre-charcoal canister, I'd imagine.
    Jan 2006
    Toowoomba
    797
    I think I found one that suits me
    AU Racing Aluminum Reservior Baffle Oil Catch Can Tank For BMW N54 335 535i xi | eBay
    The only issue I can foresee is how to mount the damn thing. Weird clamp thing it comes with.
    Aug 2002
    3,318
    You'll work something out
