vacuum amplifier valve problems
Results 1 to 3 of 3
    Romania
    10
    Default vacuum amplifier valve problems
    hi there ,
    (1994 build 306 s16 )
    Here goes: I finaly got a amplifier valve with the help of a friend , and now I am havin' problems making the system work.
    The amplifier valve is a plastic thingie with 4 hose connectors going into it 2 large white ones and 2 black ( one large and one narrow ) the valve looks like a cross , the white ones on the sides and the black ones situated down and up.
    So if anyone could tell me if I connected it wrong please tell me , any help regarding it , whould be greatly apreciated. So i connected them like this:
    1.(white-left side) to the ?vacum pump? on the engine
    2.(white-right side) the a pipe going right into the inlet manifold
    3.(black-down side) to the big round thingie - ?brake servo?
    4.(black-up side , small connector) to the solenoid valve that has connected to it the diaphragms ( dome shaped things from the top of the manifold)
    Is this configuration corect ?? Anyone ??
    I must specify that in this configuration the diaphragms don't moove they stay stuck , and only when disconnecting the pipe that goes to them they come down ...
    (Please excuse the terrible english ... )
    thanks in advance ,
    mircea
    2000+ Brad's Avatar
    2,404
    There is another component between the booster and the two diaphrams, a single solenoid which governs when vacume is given to the diaphrams. Have you got this, otherwise the diaphrams will always be 'on'.
    Romania
    10
    Icon10
    Quote Originally Posted by Brad
    Yeah I got the solenoid valve , it's shapped like a barell , and at one side has 2 connections the horizontal one goes to the diaphragms , and the vertical one I've connected to the amplifier valve , to the solenoid also comes a connector (brown) from the ecu , but still the valves are always "on".
    Should they open graduately with the increase of rpm ?? Or how should they function ... ?
    mircea
    PS: Do you happen to know how that solenoid valve is called , so I could search google , and find out what voltage is normal for that part to recieve ...
