207cc broken air filter housing
Results 1 to 9 of 9
    Feb 2017
    Sydney, NSW, Australia
    12
    Default 207cc broken air filter housing
    Have just bought a 2007 207cc convertible in showroom condition but have recently noticed a "hollow" sound coming from passenger side front. Also it is sluggish and the noise more audible under 40k. It comes up occasionally with faulty depollution system and when it did threw P2178 & P11a9 codes. It seems to have more problems when fuel tank under 1/4 e.g. DPS fault disaapeared when filled tank. I have found that the air filter housing is broken at front. Would this be causing air/fuel ratio problems and be source of noise?
    Sent from my GT-N5120 using aussiefrogs mobile app
    Jul 2013
    Newcastle/ central coast
    1,649
    Busted cat or timing chain loose even on non turbo
    8,496
    To enlarge on above- The codes indicate the system can't correct the readings from the oxygen sensor on the cat converter, and that the input timing phase shifter has reached maximum adjustment.
    It's an early engine and the chain should be checked. Many early ones, particularly turbos, but yours also, were changed while in warranty. Does it rattle (driver's side) at cold start? Converters don't thrive on excess petrol.
    Feb 2017
    12
    The timing chain was replaced in March prior to the sale to me. Haven't noticed any rattle drivers side either
    Jul 2013
    1,649
    A blocked or broken cat can cause these faults
    Feb 2017
    12
    Its at 98632k and I am getting 100k service done early on 15th September before a long drive up the coast. It sat garaged from March to May and wasnt driven as much as I have been since buying it. I am getting service done at Euro Prestige Vineyard. I have all parts and fluids etc for service and am just being charged labour. So do I have to change the Cat or just sensor and phase shifter? Any suggestions appreciated greatly
    Jul 2013
    1,649
    It is a non Turbo car ?
    Feb 2017
    12
    Yes non turbo as auto 1.6 VTI
    Jul 2013
    1,649
    Try swapping the vvt valves front to rear if not at the end of this you will probably replace the cat when they go the have an odd intake noise .
