N00b Talk: Injectors at the top of inlet?
    1000+ Posts bowie's Avatar
    Aug 2002
    Sydney, Concord City, Sir.
    3,324
    Default N00b Talk: Injectors at the top of inlet?
    Evening all,
    I've seen many engines with setups like this;
    https://youtu.be/I2B5Lkp0Au8?t=1m40s
    That is, injector and fuel rail above the throttle plate. Does this design just help with cooling the intake charge? It looks like a backfire could send atomized fuel back under the engine bay and potentially be nasty?
    7,416
    Yep, V8 Supercars etc. have been like that for a long time. It keeps the injector nose out of the flow and gives better atomisation, increasing efficiency considerably. As you say, if it back fires it can be catastrophic.
    1000+ Posts geckoeng's Avatar
    Perth, WA
    1,600
    A lot of high horse power motors have them as secondary injectors to cope with extra fuel after about 4500- 5000. This allows smaller injectors for smooth low RPM, where you want a wider torque curve. Also used on restricter motor like LeMans GT and F3.
    I think the one in "bowie's" video is such, as you can just see what is a fuel rail above the air box edge. ???
    Ray
    Ray geckoeng
    Think Old, But Run Modern !!
    Aug 2002
    3,324
    Ah never thought of them being in place with a primary set of injectors. Makes sense.
    Yes walking around the pits at work there are increasingly interesting inlet setups.
    To control for back fire, I assume a suitable plenem would encase the setup to at least limit / absorb any misshap. But perhaps not always neccessary?
