Plasma cutter - What to look for?
Results 1 to 17 of 17
Like Tree4Likes
  • 1 Post By renault8&10
  • 1 Post By 59 Floride
  • 1 Post By speaksgeek
  • 1 Post By robmac
Thread: Plasma cutter - What to look for?
    Nov 2005
    Geraldton
    1,529
    Default Plasma cutter - What to look for?
    I want a fire pit. The commercial ones I like are in the $400 price range.
    I was given a goodly amount of steel plate suited to the purpose.
    Some combination welders that include a plasma cutter come in at around that price.
    What should I be looking for?
    P
    PS I already have a stick and a balsy MIG welder.
    In the Shed(s):
    In the Past:
    4,351
    hare and forbes do a specific plasma cutter as well as the combo units I believe.
    Maybe check their website. They have a perth shopfront/warehouse I think.
    I think their website uses the address machinerywarehouse (or similar). But don't forget you'll also need compressed air supply.
    Exfrogger likes this.
    KB
    Nov 2005
    Geraldton
    1,529
    Thanks for that.
    Yep got one.
    In the Shed(s):
    In the Past:
    It's how I roll...Brisbane
    32,780
    ...and BYO plasma.
    899
    I've got no experience, but I've done a bunch of research and there seem to be a lot of people happy with the Token Tools equipment.
    I've had my eye on this for a while https://weldingstore.tokentools.com....ols-alusync215
    1984 505 Executive Auto
    206 GTi 180 - '804 Cat Cams, Jenvey DBW 48mm ITB's, Emtron KV8 ECU, HP Electronik PDM, AIM MXS Dash, Custom Wiring Harness. AST Camber Tops & Coilovers, -2deg camber hubs by Frogstomp Racing, 24mm Torsion Bars, AP Racing brakes, PeugeotSport Baffled Sump, Oil cooler, Quaife LSD, E85.
    Sandown - 1:31.5
    Winton - 1:40.2
    Wakefield - 1:13.5
    Phillip Island - 1:55.9
    Previously, 2x 504 Wagon, 505 Wagon, 505 STi, 405.
    Nov 2005
    Geraldton
    1,529
    Good one but way over budget
    In the Shed(s):
    In the Past:
    7,414
    What to look for? After sales support. I have two Hypertherms at work, but you won't buy one of those for $400. If you want a cheapy, ask your local welding supply place if they sell consumables.
    Also, 90psi of continuous dry air is a must. Thus you need a big air compressor and a toilet roll type dryer.
    899
    Would an oxy set and grinding wheel/flap disc achieve the same goal quite a lot cheaper?
    BIGRR likes this.
    Sandown - 1:31.5
    Winton - 1:40.2
    Wakefield - 1:13.5
    9,604
    You do need a good supply of air. You may find the torch consumption is higher than the duty cycle of a typical DIY garage compressor allows without stopping. Oxy will certainly cut plate steel without the need for a compressor. For both cutting systems you need some kind of guide to get a reasonably straight cut edge. A stick or MIG welder can fill in gaps left by a slightly wavy cut, but respect the duty cycle of whatever gear you are using. The time you can weld for drops off with plate thickness.
    18,424
    What do you look for ? : your hands and feet
    FWIW some plasma cutters have an inbuilt air supply
    7,414
    With a dryer? When a dash a moisture hits the tip it's all over. Kiss the head goodbye.
    18,424
    C420 | SITE CUT 10 Plasma Cutter - with Built-in Air Compressor | For Sale Sydney Brisbane Melbourne Perth | Buy Workshop Equipment & Machinery online at machineryhouse.com.au
    I've never used this product. So I know nothing about the dryer it has or doesn't have.
    Presumably it's fit for purpose.
    1000+ Posts FIVEDOOR's Avatar
    Jun 2011
    Brisbane Qld
    19,783
    Every day is a good day
    18,424
    Quote Originally Posted by FIVEDOOR View Post
    I saw that too, but I didn't want to get lambasted for being incorrect. And when in doubt it's best to shut up.
    Are you sure (I'm not) the spares are specific to this product or just general usage items ?
    FIVEDOOR likes this.
    Nov 2005
    Geraldton
    1,529
    Got a big compressor.
    In the Shed(s):
    In the Past:
    16,281
    Is that the filter that fits a roll of toilet paper as well
    7,414
    Yes, that's the one. We use toilet rolls. Cheap as, 3 ply of course. Seriously though, we do a lot of plasma cutting, both by hand and CNC. If you don't have a stable, dry air supply, you'll spend a lot of money on consumables.
