205 electrical issue question
Results 1 to 11 of 11
Like Tree2Likes
  • 1 Post By PeterT
  • 1 Post By flock
Thread: 205 electrical issue question
    1000+ Posts Isis's Avatar
    1,100
    Default 205 electrical issue question
    I put in a sneaky kill switch to cut off the (white) fuel pump wire on my GTI. The problem is that the car will not start even with the switch is turned on.
    My pen sensor lights up on the destination end of wire but wonder if the wire is now not transmitting 'enough' voltage and that somehow my additional wire or switch had introduced resistance? Is there such a possibility or is this a binary, on or off only situation?
    ta
    S3 205 GTI x 4 and getting lower
    1998 S1 Lotus Elise
    2013 Fiesta ST
    2014 Audi SQ5
    1,642
    Connections to said switch how are they made and what sort of switch are you using? Have you tried to turn it on with ignition off, turn key and listen for pump?
    307 HDi wagon
    407 HDi wagon
    1,100
    Yeah, cant say I can hear the pump working but admit I am not used to noticing it anyway.
    I am using a toggle switch and the right gauge of wire. I set the same thing up to 2 other of my cars with no problem, so this is a surprise. Perhaps my switch is different.
    1998 S1 Lotus Elise
    2013 Fiesta ST
    2014 Audi SQ5
    18,432
    Join the wires to the switch together and try again.
    1000+ Posts CEyssens's Avatar
    Jan 2016
    Berwick VIC AUS
    1,044
    Yes bypass the switch and also test the switch's conductivity with a multimeter to make sure it isn't faulty.
    1,100
    thanks you guys.
    1998 S1 Lotus Elise
    2013 Fiesta ST
    2014 Audi SQ5
    7,414
    The pump is going to pull close to 5A. So if you used a dodgy small switch it may not be able to handle the current. That's why the pump is switched by a relay. You're better to cut the low current side of the relay.
    CEyssens likes this.
    Fellow Frogger! flock's Avatar
    Feb 2014
    Brisbane, Australia
    181
    I'm sure you may already know but just in case if the switch has 3 contacts, NC, NO and Common. Make sure you haven't just connected between NC and NO.
    Sent from my E6653 using aussiefrogs mobile app
    robmac likes this.
    18,432
    You missed the lottery.
    Any combination of connections, as long as the common was connected, would have worked
    Buy yourself a multi meter, invaluable when sussing out switch connections.
    1,100
    Thanks. I did that logical thing of connecting my two end wires to bypass the switch and bingo, no problems. Switch was from supercheap so I guess you get what you pay for....
    1998 S1 Lotus Elise
    2013 Fiesta ST
    2014 Audi SQ5
    Jan 2016
    Berwick VIC AUS
    1,044
    Quote Originally Posted by Isis View Post
    Good checking... also check Peter's post, it's important to cut off the relay switch wire not the main supply that takes current to the pump
