Release handbrake cable from rear disk caliper 205 gti
Results 1 to 3 of 3
    1,809
    Default Release handbrake cable from rear disk caliper 205 gti
    Technical enough to fall into this category.
    I would like to release the brass end on the handbrake cable from the lever it attaches to on the rear caliper. It seems well and seized, Nothing seems to soak in there I suspect heat is one way?
    307 HDi wagon
    407 HDi wagon
    7,552
    Have you disconnected the cables from the handbrake lever? After that some heat and a gentle tap should separate the lever from the brass end. Removing the cable from the caliper is usually difficult.
    1,809
    Yes cable released from car, its out of the car, the brass collar is frozen into the aluminium bosy of the caliper, heat lubrication and persuasion then?
    307 HDi wagon
    407 HDi wagon
