I'm looking into my handbrake setup on my R10. I'm using MR2 rear calipers as it gets me 48mm pistons with a handbrake. The main issue is the exit position of the cable, its up and out the back.
My understanding that the Fiat calipers have a similar setup?
Has anyone used a universal handbrake cable like the one from Lokar, the ED80FU. I'll be checking to make sure it'll be long enough as it 8ft long. Mu plan would be to run it all the way to the the hand brake handle, can be cable tied to the rear tie rods.
Wilwood also makes one, same length.
