XU10 oil pump drive sprocket...
Results 1 to 2 of 2
    Jan 2011
    Traralgon
    648
    Default XU10 oil pump drive sprocket...
    I gave away the only sprocket I had quite a while ago expecting to get a replacement back with different number of teeth - didn't happen. I don't need the oil pump drive, but I need a sprocket or spacer for the crank pulley.
    Can anyone tell me exactly what width the sprocket is, and if possible the diameter (roughly) at the bottom of the tooth. I can then spin up a spacer.
    Alternately if anyone has one laying around free to a good home - that would be great too.
    Thanks in advance.
    racing 405
    1:59:09 last time at Phillip Island - less than standard Mi16.
    NSW
    634
    Send me your address I will find a xu9 or a worn xu10 one for you
    Adrian Wuillemin
