205gti press tonnage rear beam shaft change?
Results 1 to 2 of 2
Like Tree2Likes
Thread: 205gti press tonnage rear beam shaft change?
    Fellow Frogger! jech's Avatar
    Jan 2013
    132
    Default 205gti press tonnage rear beam shaft change?
    Hi, to all those with experience of pushing the rear beam shafts out of the trailing arms, a 10 tonne press shows no sign of being able to shift the old shafts. I haven't tried heat yet but is 10t normally enough or does this operation require something heavier duty? Any special techniques required?
    Cheers, James.
    Jan 2013
    132
    Well it took 10 tonnes, a blowtorch and a few hammer hits on the side under pressure. Possibly the original shafts...
