R8 / R10 fuel sender resistance
Results 1 to 8 of 8
    528
    Default R8 / R10 fuel sender resistance
    Hello knowledgeable people,
    does anyone have handy the ohm's shown for the standard sender at full and empty?
    I'm assuming full is basically 0 ohm's.
    Anyone?
    Help?
    Please?
    BR
    BR
    Building a race car is easy - building a race car that can be road registered is hard.
    For any custom fabrication call Precision One Off Engineering - Sydney 02 4587 8666
    Oct 2014
    Windsor 2756 NSW Australia
    660
    I was looking for the answer to this question and could only find this thread where Brett does not seem to get a response. I am sure I saw it on AF somewhere before ? Any answers ?
    Oct 2014
    660
    Surprised nobody knows the answer ?
    Fellow Frogger! neural revolt's Avatar
    Frenchs Forest/Sydney/Australia
    327
    From post 15 at this link:
    R8 fuel gauge sender unit access
    "the low level on the gauge corresponds with high resistance (about 500 ohms) at all of the senders. When "full" at the sender unit, the resistance varies from 1.5 to a bit over 5 ohms, depending upon which sender unit I measured up. Hmm again. These were never particularly accurate of course."
    Past Frogs:
    Alpine White 1967 R10 (round eye)
    Alpine White 1972 R16TS
    Blue 1978 Virage Wagon
    Current:
    Red 2009 Clio RS 200 CUP
    Oct 2014
    660
    Thanks for the reply. I had two senders and when I checked them both there was no resistance. Although they looked fine, one like new, when I removed the top I found that time has taken its toll on the resistors. I was thinking of rewinding the resister using my old slot car racing skills but then decided on just getting a new VDO fuel gauge and sender.
    Since the tank is out on this project, its easy to change the PCD on the sender mount. The last time I did that modification I had to gain access to the tank through the inspection hole in the rear parcel shelf of the R8.
    1000+ Posts geckoeng's Avatar
    Perth, WA
    1,771
    "Busta.."
    See Graeme's Gordini for my modification of tank for VDO units.
    Ray
    Ray geckoeng
    Think Old, But Run Modern !!
    Oct 2014
    660
    Thanks Ray, I found the page with the pics of the modified clamp ring etc.
    1000+ Posts Frans's Avatar
    Auckland
    1,556
    FWIW I have 2 units and both measured 350 ohms +- 2ohm.
    Frans.
    Old enough to know better
    Young enough to do it anyway.
