R$ with R16/17 running gear
    Fellow Frogger! sapito's Avatar
    Apr 2004
    128
    Default R4 with R16/17 running gear
    Is it possible to do this to the little R4.
    Or has anyone done it?
    Ipswich, Queensland.
    1,886
    Nothing is impossible, just difficult. A 16 motor and gearbox are facing the right way, but the gearshift might cause some anxiety. A guy in Holland(I think)has a hot R5 Turbo in a R4, that being an easier swap. Although the late R4 gearbox that had the Sierra type motor, would easily accept a 16 bell housing. Just not very common here, 10s of thousands in Europe.
    Certainly an oddity, but then you would have to give it some brakes and handling. I have driven a friends' stock 845cc powerhouse and couldn't get the smile off my face.
    '56 Renault 750 (16TS Power)
    '62 Renault Dauphine Gordini
    '08 Renault Megane sedan
    1000+ Posts Haakon's Avatar
    May 2002
    canberra...
    8,747
    would it even fit? The sierra motor is a tight fit and the alloy R16 mtor is a lot bigger. Better off going the Turbo Sierra route - they are a tough little bugger and can be made to produce silly amounts of power (more than I would want in an R4 at any rate )
    Apr 2004
    128
    Default r4
    Its just that the twink is very common in wrecking yards and turbos arent.
    Also alloy block nice on the front end.
    Has to have the 5 speed too
