Help. Where to start Mi16 build? - Page 2
Page 2 of 2 First 12
Results 26 to 41 of 41
  1. #26
    743
    There's quite a lot of useful info about the EW engine here:
    Embrace The Ew! - Non-XU/TU Engine Maintenance and Performance Upgrades - 205GTIDrivers.com
    That said, I wouldn't bother to do the conversion from XU to EW. There's plenty of scope for tuning on both, and the end place is pretty much the same as far as I can tell - between 220 and 300HP depending on your wallet.
    206 GTi 180 - Cat Cams, Remapped Group N ECU, AST Camber Tops & Coilovers, -2deg fixed camber hubs by Frogstomp Racing, 24mm Torsion Bars, AP Racing brakes, Yokohama A050, PeugeotSport Baffled Sump, Powerflex Engine Mounts & Bushings, Setrab Oil cooler, Quaife diff, Velo seats.
    Sandown - 1:31.5
    Winton - 1:45.6
    Phillip Island - 1:58.4
    Previously, 2x 504 Wagon, 505 Wagon, 505 STi, 405.
  2. #27
    Perth
    70
    I seem to find different information.
    A 2000 Peugeot 306 XT will have an XU10j4R ? Even an automatic sedan?
    And would be a good purchase, in lieu of finding an RS variant.
  3. #28
    Jan 2011
    Traralgon
    621
    Differences between r and rs engines:
    RS
    2.5 mm taller block and longer rods
    Lighter valve train, smaller stems
    Bigger cam journals
    Oil squirters in block under pistons for piston cooling.
    In factory form rs must be a slightly better engine to spank, but when building highly modified, not really much difference. Oil squirters the only thing I went looking for and why I started with XU10J4RS.
    racing 405
    1:59:09 last time at Phillip Island - less than standard Mi16.
  4. #29
    Perth
    70
    Thanks. What I am trying to figure out is if I will get similar results. And reliability
    As I'm one for sharing. Pug1Off have been good saying
    The R engine is ok as long as you bore the block .001’ over the recommended setting. The extra thou of wall clearance allows for a bit more expansion of the piston without the cooling effect of the oil below. Many race engines will have these blocked to reduce drag anyhow.
    Also saying the head has a 0.5mm larger inlet valve and a slightly smaller exhaust valve which is actually beneficial so the only thing youd really need to do, from memory, is swap the valve guides to gti6.
    That engine doesn’t have sequential ignition but I don’t find any power advantage to using it anyhow.
    CatCams 4903110 there is a single spring option
  5. #30
    Perth
    70
    Thanks again gents.
    I have in my possession a running XU10J4R from a 2001 Pug 306.
    @PeterT what would be the suggested approach on cams for this engine, regrind or Cat cams single spring cam as above?
  6. #31
    7,076
    The XU10J4R cams are too small to regrind any worthwhile profile. You'll need to buy new Catcam billets and springs. Expensive. Thus why I suggested staying with an XU9J4 or XU10J4 head, which you can still put on the XU10J4R block.
  7. #32
    Perth
    70
    Thanks PeterT. Somehow I didn't see your response. Anyway, I'm going to make the XU10J4R work, as it was the best priced option I could get hold of - the Catcams and springs don't seem very expensive.
    How much am I affected by the rod length?
    Any tips on the following combination?
    You will have to excuse if I haven't taken in all advice, I've read it - probably just not understood.
    Do these Cams get me anywhere near the Gti-6 head reground cams?
    Wossner Pistons 86x86 - preferred classes dictate 2L
    PEC Rod Set
    King Race Big End Bearings, and all new Bearings
    CatCams 4903110 Camshafts and Catcams Single Valve Springs for XU10J4R, CatCams Retainers
    Vernier Pulleys
    Adjustable FPR
    412cc Injectors
    4-2-1 Manifold
    Satchel short intake and EFI hardware ITB - as suggested
    Baffled sump - trying to keep the engine bay and ancillaries neat
    Valves, are Inlet/Exhaust from Catcams worth it on this engine?
    Will be run by a Motec
  8. #33
    7,076
    Surely you can use 86.50 pistons? Otherwise the bore won't clean up. Most classes allow a few percentage tolereance. Use a 3 bar fixed fuel reg, which fits in the end of the EFI Hardware fuel rail. You will need an accumulator, eg Moroso or Accusump. I wouldn't change valves unless yours are damaged.
  9. #34
    743
    Quote Originally Posted by BG5WRC View Post
    I'm sure a baffled sump is useful, but my understanding is one of the biggest flaws in all XU engines is oil surge on (left hand?) corners. Common wisdom is at least an accumulator, or a dry sump if moving to slicks is pretty much compulsory if you want to avoid engine damage. It's not strictly necessary to live in the engine bay.
    Sandown - 1:31.5
    Winton - 1:45.6
  10. #35
    8,314
    I'm using a Constella sump baffle(from the UK) on my gravel 309 rally car with XU9 J4. This is a works copy, although they also used an extended sump (steel). I have used the original 309 GTi sump which is steel. Also, the engine has solid lifters with a restrictor so less oil up in the cam cover at high revs. Has been fine so far, did a 400 km stage distance rally in early June and am not expecting any problem in the future on gravel.
    However, more in line with what you are planning,I have entered the all bitumen Adelaide Rally in December so may install a large oil pressure light for this so as to keep a close eye on what is happening! Will be using RE002s not slicks and won't be going absolutely flat around known corners as on a race track. so hopefully it will be OK
  11. #36
    Perth
    70
    Thanks guys. Taking note of the oil warnings. Probably the time and money to make the wet sump stronger ends up a chunk of what it will take to dry sump. Makes for one very exxy engine build.
    Sent from my Pixel using aussiefrogs mobile app
  12. #37
    Jan 2011
    Traralgon
    621
    If you're running batch injection at 3bar, check the injectors are big enough. Injection time at 9000 rpm is very short.
    racing 405
  13. #38
    Perth
    70
    412cc ?
  14. #39
    7,076
    Yes, that's ok for petrol and sequential injection but on the limit for multipoint. You'll need 25-30% bigger for E85.
  15. #40
    Perth
    70
    Thanks again. Am I better off buying injectors from EFI Hardware to match their ITB kits? The EFI ones range from 440 - 550cc.
    Also confirming going with 86.5
    Heated screen is also on order to simplify the engine bay, and dash area
  16. #41
    7,076
    Yes, that way you'll get the correct height injector and fittings.
