New tech dual mass flywheels , a look at what they are!
Results 1 to 12 of 12
Like Tree10Likes
Thread: New tech dual mass flywheels , a look at what they are!
    Newcastle
    2,798
    Default New tech dual mass flywheels , a look at what they are!
    Hi
    I looked this up for someone who had been diagnosed with a failure of his flywheel. Feels expensive too
    As I know little about these "new fangled gadgets" I though it might be of interest to other old fogies on here also ! Plenty more where that came from but I thought this one was clear and concise
    http://www.understeer.com/pdf/dualmass.pdf
    jaahn
    1000+ Posts FIVEDOOR's Avatar
    Jun 2011
    Brisbane Qld
    21,046
    Every day is a good day
    Jan 2017
    NZ Auckland papatoetoe
    67
    Look up a new kit for sale on micks garage.com
    Include a new flywheel and buy a normal clutch instead
    Sent from my GT-I9505 using aussiefrogs mobile app
    John Handley
    Guest
    Hi. I would like to chip in here that I had a mate with a petrol BT50 ute with a crook clutch. I replaced the DMF for him with a regular clutch conversion kit. Honestly, I couldn't tell the difference from before when the DMF was working. And the kit cost about half the price of the new DMF kit. I reckon they are a bit of hoax, and an expensive one. That's just my one time experience, so maybe not much to bet the bank on.
    Cheers, John.
    11,302
    Thanks for that. Interesting - I had no idea they were made that way! Judging by the troubleshooting comments, they are a bit vulnerable to bad/rough driving. I've come across the odd failure at low km from people known to people I know....
    See also Dual Mass to Single Mass flywheel conversion for a warning about assuming that because one conversion to a single mass was OK the next one will also be OK!
    I presume it is basically about smoothing out something a bit rough in rotational accelerations, a bit like WO Bentley discovered when he needed rubber engine mounts for his first, 3-litre car.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    Member s9810588's Avatar
    Sep 2013
    39
    I had unpleasant and expensive experience changing from DMF to SMF.
    In my case, VW/Audi 2.0L turbo engine does not have harmonic balancer and uses DMF to balance torsional harmonics. The SMF combo lasted 12,000km before it started making horrible metal screeching noise. Back to DMF and I have no problem since. The mechanic had first hand experience of spun big end bearing on the Golf R32 V6 engine that has gone to SMF.
    What an expensive experience having to buy two clutch & flywheel kits twice in two years and the labour to change clutch. The SMF clutch kit wasn't a cheapo either - it was ZF Sachs one.
    Dec 2002
    CANBERRA
    400
    Swapped from DMF to single on my 2.5l diesel Pathfinder years ago. Initially it felt a bit rougher but we soon got used to that and now more than 150,000 hard kilometers later I'm still grinning (DMF only lasted 95,000).
    1000+ Posts N5GTi6's Avatar
    1,119
    The SMF clutch on our GTi6 with 190nm of torque lasted 110K km's
    The DMF clutch on our 308 2.0 HDi with 320nm of torque is still going @ 190K km's - although of course now I've said that it will die any day now......is this an Old tech dual mass flywheel or a New tech dual mass flywheel ?
    Justin
    '07 C3 Exclusive
    '10 308 Sportium Touring
    '12 Megane RS265 8:08
    CitroŽn Tragic UFO's Avatar
    9,809
    Quote Originally Posted by N5GTi6 View Post
    Justin
    You've said it twice now. You're really tempting fate!
    1,119
    Thanksfully the Delorean doesn't have a clutch so I went back in time and fixed that up ...
    Justin
    '07 C3 Exclusive
    Jan 2011
    Traralgon
    648
    My 306 did it's entire life without a clutch change. Just about 250k and the clutch was still serviceable when it went in the bin.
    racing 405
    1:59:09 last time at Phillip Island - less than standard Mi16.
    1000+ Posts Kim Luck's Avatar
    Melbourne, Aus.
    18,563
    Quote Originally Posted by racing405 View Post
    Like every manual car should, driven by mechanically sympathetic drivers....
