Peugeot 205 gti speedo cable varieties
    Mar 2005
    perth
    133
    Default Peugeot 205 gti speedo cable varieties
    Hi, I'm wanting to know if all 205 gti speedo cables are the same? Not sure if they have the same ends and are the same lengths?
    9,310
    Not sure about length, but I have one brand new here with different end fitting to the one in my car.
    I didn't try to see if it works with my car, it isn't clear either way.
    Length seems similar.
    ACHTUNG ALLES LOOKENPEEPERS
    Fellow Frogger! flock's Avatar
    Feb 2014
    Brisbane, Australia
    203
    When I converted my series 1 to series 3 dash I had to cut the rubber flange that holds it into the series 1 dash, and it plugged in fine to the series 3 instrument cluster from the UK.
    Sent from my E6653 using aussiefrogs mobile app
    9,310
    My cluster came from Germany and the old speedo cable fit straight in, no mods necessary (BE1 box, series 1 car, german cluster of unknown car).
    Mar 2005
    perth
    133
    Nice! Thanks for the info. Sounds like they are "fairly" compatible with all series. Will track one down. Cheers
