505 GTI diff noice at 120km/h?
Results 1 to 24 of 24
Like Tree11Likes
Thread: 505 GTI diff noice at 120km/h?
    1000+ Posts parry's Avatar
    Sydney Australia
    1,334
    Default 505 GTI diff noise at 120km/h?
    Took the 505 for a drive this morning on some nice country roads, all seems good with the car except once I got on the freeway there was a noise at 120km/h coming from the drive train. It did seem like it was the diff but not 100%. The noise goes away if you go off load or take the car out of gear at that speed.
    Soon, I will be taking the car on a 8,000km outback journey so want to have this looked at, any suggestions where to start?
    Car is a 1985 GTi 5 speed. 392,000 kms on the clock
    90 205 Gti Cherry Red(Track Car)
    2009 207gti
    1985 505gti (Shitbox Rally) Sold
    PBs:
    Oran Park: 1:27:9
    Wakefield: 1:05.6 (July 2015)
    Eastern Creek: 1:47 (16V) 2019
    Mt Huntley: 34.44 (2004 stock 205)
    Ringwood: 35.06 (30/10/2005)
    Winton: 1:33.6 (2017)
    Dec 2002
    Menzies Creek
    2,555
    My bet would be on the fifth gear bearing in the back of the gearbox. See if it does the same in fourth.
    But nonetheless, check the diff fluid anyway...
    Scotty
    Melbourne - Dandenong Ranges
    2014 Peugeot RCZ - 'Remy'
    7,551
    Banana skins.
    Sydney Australia
    1,334
    Quote Originally Posted by Demannu View Post
    If I stay away from the Noise zone will it last the trip, lots of 5th gear driving!
    2009 207gti
    PBs:
    Oran Park: 1:27:9
    1000+ Posts BIGRR's Avatar
    Feb 2006
    North Rocks, Sydney
    2,467
    When/if 5th craps itself, you can use 4th it's 1:1 and is within 5% of the same overall ratio as 4th (Top) in a 504!
    Peugeot
    Present fleet:-
    Peugeot 93' 205 Gti 16v
    Peugeot 73' 504 Ti from new
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 72' 16TS from new
    Renault 69' 10
    Renault 71' 10s
    Renault 68' 10 from new
    "Be reasonable do it my way!"
    Sydney Australia
    1,334
    Does it in 4th as well...So I am thinking diff or driveshaft center bearing,,,Maybe needs greesing
    2009 207gti
    PBs:
    Oran Park: 1:27:9
    NSW
    634
    Could also be the splines on the driveshaft
    Adrian Wuillemin
    1000+ Posts Beano's Avatar
    3,201
    You could always jack it up, put chocks under the wheels, handbrake on and get underneath while it's in gear. Only one rear wheel will be turning. Use a piece of wooden dowel as a stethoscope.
    I did this once and was amazed at how noisy gearboxes are.
    You want to eliminate the gearbox and diff being the problem before you start thinking it's the centre bearing. Having said that, I think my own centre bearing is stuffed, though I haven't eliminated the diff 100%.
    People in garages don't realize the grease nipple even exists halfway down the prop shaft and it doesn't get greased.
    How long have you had it, and who did the previous owner take it to for servicing ? Specialists, or the local garage ?
    Jun 2014
    Sydney, NSW
    240
    When I first got my 505 there wasn't positive evidence of recent greasing on either centre bearing or steering rack so I've done those twice in the space of 5K kM. Changed oil in gearbox & diff too. I have noticed a momentary grating noise coming from back end when turning sharp left, I'm assuming it's the sticky-diff protesting the new oil.
    may all your plans be cunning ones,
    Baldrick,
    fleet: 1989 Peugeot 505 GTi Wagon
    1969 Peugeot 404 Sedan
    2003 Smart 452 Roadster
    2005 MG ZR160
    1988 Mercedes 300E
    1953 Citroen 15CV (under Restoration)
    1953 Bristol 401 (under Restoration)
    That's one for each day of the week - I really should stop
    Armidale
    2,584
    Quote Originally Posted by Beano View Post
    Does the hand brake on 505s operate on the front wheels? Sounds unlikely...
    3,201
    Oops.
    Erm...anyway, you'll be amazed at how noisy diffs and gearboxes are. But listen through the stethoscope for the same tone you heard.
    Very unlikely to be the centre bearing. They just it there, with no real pressure on them.
    1000+ Posts Peter C's Avatar
    SWOTR
    3,873
    Beano is right. Manual 504 gearboxes in good condition sound really noisy if you drive the car around the block with the centre console and metal gear lever cover removed.
    1000+ Posts driven's Avatar
    Apr 2005
    1,564
    When the noise stops the car will also stop.... EASY
    351
    Put the appropriate Nulon in both the gearbox and the diff as well as grease the centre bearing.
    Jun 2014
    Sydney, NSW
    240
    Quote Originally Posted by neil s View Post
    Not convinced by the 'Nulon' snake oil, but I did add 5% 'Moly Tech' additive @my gbox oil change. Yep I know it's for 'engines' but you're using engine oil :-)
    Baldrick,
    2005 MG ZR160
    1988 Mercedes 300E
    3,201
    Quote Originally Posted by Peter Chisholm View Post
    Not just noisy. In my old 504, with all the clattering and crunching, you'd swear the gearbox was going to disintegrate in the not too distant future !
    SWOTR
    3,873
    Yes, that's exactly what it is like and it's a real revelation to hear it without the cover etc. I can only imagine what a faulty gearbox sounds like. When you realise just how noisy these things are you wonder how they last.
    3,201
    Like certain posters here and on other forums like Facebook, eh ?
    tweed heads
    1,544
    A mechanic friend of mine was telling me yesterday of a light truck gear box he had worked on [ twas noisy],upon removing the top plate that housed the shift leaver ,he found the box to be full of meat ,didnt smell very pleasant ,he recons its an old trick ,first time i have heard of it
    SWOTR
    3,873
    Quote Originally Posted by pugwash View Post
    Must've belonged to a butcher.
    Perth Western Australia
    2,705
    Back in the day. Volvo trucked down from Geraldton to Perth. Workshop order says "overhaul diff." Duly done with new bearings etc. Nothing evidently wrong with the old.
    Road test on completion, howling noise increases with speed. I was driving with service manager and Volvo state engineer as observers.
    Short story longer. Wind noise through tubular roof rack.
    I thought you would ask. Difficult to initially road test with diff boxed up in boot!
    19,214
    Contrary to others opinions, replacing the oil in my BA 7-5 with Nulon oil made a a considerable difference to smoothness of gear shift and noise. The oil was on special at the supplier and this was first experience of Nulon oil.
    tweed heads
    1,544
    I also recommend nulon was wondering if that truck had a wagyu shift kit ,whilst driving i was wondering how one would ,put the meat in there ,stir fry through the filler hole a strip at a time ,possibly .pugs
    19,214
    There are likely forums to visit that give advice on placing large amounts of meat in small orifices.
