760 V6 motors
Results 1 to 15 of 15
Thread: 760 V6 motors
    Fellow Frogger! MR604's Avatar
    May 2002
    Bathurst
    946
    Default 760 V6 motors
    Just a quickie, are the 760 ovlov V6 motors the same as the 260 ones?
    These one's had the electronic fuel injection and the injectors mounted into the manifold insted of the head, so I've been told, so they should be easy to bolt a carby onto?
    Has anyone used one of these motors in their Pug?
    I've been searching on the net for info on them, but I haven't had much luck yet.
    Thanks for any help
    A computer lets you make more mistakes faster than any other invention in human history, with the possible exception of handguns and tequila. - Mitch Radcliffe
    12,256
    Quote Originally Posted by 2 pugs
    Thanks for any help
    basically they are the same but the spacing between the heads is different and as such the mainfolds are not interchangeable
    also they run a 6 journal crank making them an even fire engine
    you can mount the injectors from the 260 series into the manifold and still use the pug heads from what i have found out
    i'll either use pug heads with a modified inlet or the volvo heads yet but i am more inclined to use the pug heads and use the 2849 liners and still retain the 3 journal odd fire crank
    as much as i would like to go for electronic injection the mechanical system used on the volvo is pretty straight forward and easy to fathom out
    with the mechanical version you also have to use the volvo water pump BTW
    in the interim i am after an early 504 air filter to modify for the carb on the 604 as i have had in the past with great results
    1 x '98 306 GTi6
    May 2002
    Bathurst
    946
    Thanks.
    I was looking at one but didnt want to mess around with injection at the moment.
    Looks like it'll be easier and cheaper to rebuild the 2.7 at the moment.
    12,256
    Thanks.
    yours blew the head gasket didn't it ?
    how many km's are on the engine ?
    what are your plans with rebuilding the engine, ie how far are you looking at going with it ?
    1 x '98 306 GTi6
    May 2002
    Bathurst
    946
    We replaced the head gaskets, but it didn't solve the problem.
    We're going to strip down the motor and rebuild it this time
    If that doesn't work it'll be time for the shell/redhead fix
    12,256
    still loosing water ?
    bubbles in the radiator ?
    water in the oil ?
    when you filled it up did you use a funnel to get the water level higher than the engine and pump the hoses by hand to get all the air out
    how much water is it loosing or is it missing when running and pumping out steam ?
    there are quite a few places where water can leak from on the PRV engine
    also when putting everything together make sure the overflow line on the top of the water pump is clean so that coolant can get to the bottle otherwise you get pressure build up
    1 x '98 306 GTi6
    May 2002
    Bathurst
    946
    water in the oil ?
    It's doing all of the above
    There's about 250,000 on the motor, so a freshen up will give it a new lease of life.
    The adventure begins this weekend
    12,256
    not good
    hopefully it's only liner seals and nothing major like a corroded block
    let us know how you go
    i do know of a near complete PRV sitting in a 604 not far from here if it comes down to you needing any major bits
    1 x '98 306 GTi6
    Fellow Frogger! OddFireV6's Avatar
    152
    If I can just clarify the comments comparing the Volvo 760 even fire with a Peugeot 604, the heads are in the same place and exhaust manifolds are interchangeable however the inlet port of the even fire motor is higher up the head which creates a dramatically better inlet port for flow. This does mean however that inlet manifolds are not interchangeable. The other issue with using an even fire motor is that the engine management computer controls the spark, there is no separate ignition triggering mechanism, only a high tension distributor on the end of the passenger side camshaft.
    OddfireV6
    504 V6 24V, 203
    Dec 2002
    211
    OddfireV6, what sort of turbo/s are you running on the 505V6?
    Are you using an LSD?
    152
    I'm using an ancient T04 with a Commode/ nissan centre housing, an external 42mm wastegate with variable boost control and an intercooler from a Toyota Supra, the engine is a standard 2850cc oddfire Volvo. This setup will be for sale eventually I'm moving to a 3 litre evenfire and twin turbos. I suggest you to join the Peugeot club of Victoria where I regularly write on the joys of making 504s and 505s go fast.
    And yes both the 505 and 504 have LSDs, I would not be without them, the factory parts to convert are around $450 new and only take a few hours to fit. The unit in the 504 has performed faultlessly, often used in competition, for over 10 years.
    OddfireV6
    504 V6 24V, 203
    Dec 2002
    211
    Icon4
    TO4??? It must fly!!! How much bhp are you getting at the wheels? Which Supra Intercooler are you using, the 2, 2.5 or 3 litre version? Where do you get the LSD bits?
    9,179
    Quote Originally Posted by Nisspug
    Sign up for the next bulk buy of Quaife diffs. in June I think.
    Graham Wallis
    152
    It goes OK, particulary in the launch, but the twin turbo (2* TDO4L) 505 V6 turbo sucks the doors off mine, it has never been on a dyno but compared to my 'normal' cars, a C36 AMG Merc and the 406 V6 I'd say its in between them somewhere. A pertinent point is that both turbo V6 505s I'm talking about run straight LP gas, if you know your fuels Victorian LP Gas is about 110 octane, higher than premium unleaded so you can crank up the boost to compensate for a lower energy per litre than petrol.
    I source my diff bits from European Auto imports in 23 Clarice St. Box Hill Victoria.
    OddfireV6
    504 V6 24V, 203
    Dec 2002
    211
    Icon4
    Just a thought, but I've read that the Supra intercoolers are quite restrictive and by installing a bigger aftermarket 'cooler the improvement in power is quite dramatic, especially with a big flowing beast like the TO4.
