Part number for caliper repair kit R17 ?
Results 1 to 11 of 11
Thread: Part number for caliper repair kit R17 ?
    1000+ Posts Shoji's Avatar
    Jan 2012
    Mandurah WA
    1,193
    Default Part number for caliper repair kit R17 ?
    Could someone confirm that this part number suits the R17 tl from the renault 12 shop
    7701010264
    I don't have the book. Cheers Frogstars!
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,336
    Quote Originally Posted by Shoji View Post
    7701010264
Name:	Repair set brakes.jpg
    Hi Shoji
    The part number is correct going by the parts books I have here, but they are 54mm not 56mm but that maybe just a typo.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    Jan 2012
    Mandurah WA
    1,193
    Hi Shoji
    Hi Col. How's the weather in my home town of Hobart?
    Thanks for the heads up. I will check with Marleen in Holland on the size.
    I went to fit the torsion bar pens and they ended up being longer than the original???
    They are not advertised as being for the 17 - only the 12.
    So another question is, are those part numbers for the pen different to the 17? Part number: 7700556736.
    Cheers. John
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,336
    Cheers. John
    Not sure what the weather has been like in Hobart but up north it has been great (summer is back again)
    Not exactly sure what you mean by torsion bar pens, I am assuming you mean the drop links from the top wish bone down to the torsion bar. If they say that they fit the R12 you would think that they would fit the R17 because the suspension is the same except for shock and spring rates.
    Regards Col
    1973 Alpine A110
    Jan 2012
    Mandurah WA
    1,193
    Your correct. The drop links. I pulled one off to replace and low and behold they are different in length.
    The thread is almost touching the lower wishbone making near impossible to attach the washers, rubbers and nut.
    This without the torsion/sway bar off the car. As well, I have to knock the wishbone pin in a bit to attach the drop link.
    it is too long.
    Col. Would you have the part number for comparison?
    You may have rain today. Launie may have a shower. Burnie with a chance
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,336
    Hi Shoji
    The part numbers for the drop links that I have here are as follows
    Renault R12 R1330-R1337-R1338 77 01 453 465
    Renault R15 R1300-R1301-R1302-R1304 77 01 453 465 & 77 01 452 078
    Renault R17 R1313-R1317-R1323-R1327 77 01 453 465 & 77 01 452 078
    These parts numbers include the drop link with washers, rubbers and nut
    I'm not sure what the difference is in two numbers, it maybe length.
    Just as a comparison the ones on my 76 wagon which are not original there is a distinctive gap between the drop link and the lower wishbone and on my 73 wagon which has original drop links, which are almost touching the lower wishbone.
    The 76 wagon is complete and sitting level and the 73 wagon is just a shell so its front is raised so may make a bit of difference.
    Can you possibly cut some thread off the bottom of the drop link to make them fit and still leave enough thread protruding out of the nut when done up tight?
    I also find that having both wheels at the same height makes the fitting of the torsion bar easier.
    Regards Col
    1973 Alpine A110
    Jan 2012
    Mandurah WA
    1,193
    I'm worried it might throw the front out of spec if I fit these longer drop links.
    It will push the bar down
    I do have new sway bar bushes to fit, so I might try the drop links on the weekend.
    Jan 2012
    Mandurah WA
    1,193
    So many varying part numbers??
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,336
    The only spec that it will change is roll stiffness, and I don't think you will notice any difference as long as the drop links don't touch the lower wishbone.
    Regards Col
    1973 Alpine A110
    Jan 2012
    Mandurah WA
    1,193
    Remove the bar and the drop links. Gave the bar a fresh coat of paint and wacked it back on with the new droppers. Had to cut only 5mm off the threads. Thanks for your help Col!
    Sent from my SM-J100Y using aussiefrogs mobile app
    9,320
    I have seen drop links that scratch the lower wishbone as well. It may be just variance between manufacturers. No adverse effect if you need to cut a bit off the end to fit, but you can always attach the sway bar end in first and then attach to upper wishbone. Both sway bar ends disconnected, of course, and don't do up the bottom drop link nuts before you connect at the top. Might need a bit of compression of the spring to take the load off the shock bottom bolt, just in case you need to slide it in and out a bit, but not really unavoidable (a soft face hammer does the trick just as well).
    ACHTUNG ALLES LOOKENPEEPERS
