Crunchy gears!
Results 1 to 18 of 18
Like Tree4Likes
Thread: Crunchy gears!
    3,612
    Default Crunchy gears!
    My newly purchased 2CV van wants to crunch in first and reverse. I sometimes avoid crunching in first by putting it in second first, and that seems to help. If the clutch is faulty, should it not crunch in all gears? Or perhaps the synchros are stuffed?
    It's how I roll...Brisbane
    33,940
    Um, is it an all syncro box..? I suspect there are no syncros in first or reverse.
    Every day when I wake up I reach up in the darkness with my eyes shut and if I cannot feel anything that resembles a wooden lid I know it will be a good day. No lid today.
    3,612
    Quote Originally Posted by 59 Floride View Post
    No, not in first anyway, but they should not crunch when stationary.
    1000+ Posts Peter C's Avatar
    SWOTR
    3,873
    Clutch not disenagaging properly or faulty gear selector/gear lever mechanism?
    1000+ Posts cam85's Avatar
    Nov 2003
    Bondi
    3,441
    Sounds like the incorrect release bearing (or the clip not attached to it).
    94 205 Gti Classic #9
    91 205 Si
    87 205 GTi Race Car
    3,612
    I have noticed from day one that the gear leaver, the one coming out of the dash, has a marking on it. Pushed in to the mark and flush with the dash, thats when it is in neutral. But with the van, when in neutral, that mark is about two inch out?
    9,467
    It will be a dragging clutch.
    3,612
    Well, I have done nothing as yet to fix it, but strangely, it fixed itself. have used it a fair bit in the last week or so, and perfecto! Weird! Two weeks ago I did sprayed the clutch cable housing (tubing), with silicon spray. ?
    1000+ Posts BIGRR's Avatar
    Feb 2006
    North Rocks, Sydney
    2,467
    Quote Originally Posted by bad bertie View Post
    well, i have done nothing as yet to fix it, but strangely, it fixed itself. Have used it a fair bit in the last week or so, and perfecto! Weird! Two weeks ago i did sprayed the clutch cable housing (tubing), with silicon spray. ?
    age????
    Present fleet:-
    Peugeot 93' 205 Gti 16v
    Peugeot 73' 504 Ti from new
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 72' 16TS from new
    Renault 69' 10
    Renault 71' 10s
    Renault 68' 10 from new
    "Be reasonable do it my way!"
    9,310
    My first question would have been about the g'box having synchros, but I think others have clarified that.
    I guess you have found a way to deal with it, but it can't hurt checking if there's any (or enough) oil in the box.
    ACHTUNG ALLES LOOKENPEEPERS
    1000+ Posts Beano's Avatar
    3,201
    Quote Originally Posted by Bad Bertie View Post
    It looks like YOU fixed it, rather than it fixing itself.
    And Aussiefrogs CSI has a winner !
    Quote Originally Posted by Peter Chisholm View Post
    Mar 2011
    Linton.Victoria.
    1,278
    Must be an Automatic [Fixer]...Should command an excessive value when & if you sell..........
    ......Meanwhile,back @ the Ranch you will be able to log the other 'Automatic Fixes.....
    11,294
    flywheel spigot bearing freed up with a bit of use?
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    1000+ Posts FIVEDOOR's Avatar
    Jun 2011
    Brisbane Qld
    21,027
    Silicon spray worked through and freed up clutch cable?
    Every day is a good day
    3,612
    I once had a 2CV with low level of gearbox oil, and what happened wasn't crunching gears, but rather very heavy, like going through almost dry cement!
    3,612
    Quote Originally Posted by FIVEDOOR View Post
    Maybe, but you think it would have affected all the gears? anyway, I am not complaining now as all is well. Touch wood!
    3,612
    Yes this car had very little use since its rebuilt some yers back in South Africa. Even the door rubbers are so new and stiff, the doors will not shut easely!
    3,612
    Quote Originally Posted by BIGRR View Post
    age????
    Age of reason.
