Pod Filter on Series 1 BX 16 Valve
    Fellow Frogger! sproose16v's Avatar
    263
    Default Pod Filter on Series 1 BX 16 Valve
    Guys need some advice
    I have a pdo filter laying around from a mate of mine, and was wondering how hard is it to put this on the 16 Valve? Id probably have to change a few things around i.e. AFM! Do i need a different induction pipe or whatever? Any ideas?
    Fellow Frogger! Jason20's Avatar
    Oct 2003
    Sydney, Australia
    439
    If it has an airflowmeter anything like a 405 mi16. the opening is square, so you need a bracket that screws to the air flow meter, then the the pod plugs into the brackets square end and is screwed in secure.
    I think most pods these days have circular adaptors not square.
    also depends if you want it to be put directly to the airflow meter, or run a pipe to its further away, which is the way to go. But easier said than done.
    1000+ Posts Warwick's Avatar
    Nov 2002
    2,664
    Some were square, some weren't I believe.
    Member josephk's Avatar
    Jul 2003
    east melbourne
    95
    I have had alook at my 16 Valve and its the same as our MI16, SQUARE !! and an adaptor would be needed. Having looked at the position for cold air flow , you could turn run a pipe fron the rear of the RH false air intake, up through inner guard and coming out just under the pod filter, cheers josephk
    eugeot 2001 406 Coupe Polo Green.
    :Saab 9-3: 2000 Viggen Convertible Lightning Blue, BSR 424NM frightening!!!
    :Saab 95: 2001 Aero Black Wagon. 184kw .
    :Saab 900: 1993 Classic Convertable Blue.
    $$$ SAVE BANK INTEREST AND BUY MORE TOYS!!
    263
    Lads
    Thanks! Anyone know where one could find an adapter? Are they as rare as s**t or easy to find?
    1989 BX 16 Valve Mk1 - SOLD (And Missed)
    http://www.bx16v.cjb.net
    1992 R32 GTSt Skyline
