Sump plug washer?
Results 1 to 10 of 10
Like Tree9Likes
Thread: Sump plug washer?
    668
    Default Sump plug washer?
    I fitted an aftermarket alum sump (from Mecaparys) and recently did an oil change on my R8.
    I reused the sump plug and copper washer, but now has a light oil leak. Is the copper washer correct or should I have used a fibre or plastic washer?
    Angelo
    COL
    COL is online now
    A110 COL's Avatar
    Van Diemen's Land
    4,331
    Hi Angelo
    You need some of these:
    crushable copper washer | eBay
    Change the washer every time you do an oil change and it won't leak.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    668
    Thanks Col, it seems that I need to stick with copper.
    I will get some and it should solve the slight problem.
    thanks
    angelo
    Attachment 93511
    11,293
    No other "slight" leaks? Well done! Mine's been as dry as a chip since 1988 regarding the sump, but the odd wee drip from the clutch and crownwheel carrier areas - trivial as you can park on clean concrete and not leave any mark. They do seal well when you get it right. Better to keep the hexagon sump plug I reckon, so you can nip it up reasonably tight (not ridiculously).
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    668
    Gbox is fine and will get the sump washer sorted soon, but as I have just filled it with new oil, I will have to drain it out and fill it again and hope it doesn't leak again.
    next is checking the cooling system. As I did a Alpine radiator conversation (radiator from rear to front slimline using aluminium tube and plenty of rubber hose bends with many clamps) I hope that the leaking won't be too bad.
    i also have the brakes to fill with fluid as well, but one job at a time.
    angelo
    1000+ Posts driven's Avatar
    Apr 2005
    1,564
    Did you put any oil in ??
    11,293
    ROFL.
    Here it is about half way across Australia.
    Attached Thumbnails Attached Thumbnails Sump plug washer?-r8-madura-pass.jpg
    668
    Hi Angelo
    Delivery for the crushable copper washer was going to be mid Feb and I couldnt wait, so picked up a handful of these from Champion in Arden St, Nth Melb.
    Seems to have done the trick.
    (Sorry abou the upside sump pic, i cant work out how to flip it over)
    Attachment 93613Attachment 93614Attachment 93615Attachment 93616
    1000+ Posts FIVEDOOR's Avatar
    Jun 2011
    Brisbane Qld
    21,025
    Flipped and ...
    Every day is a good day
    1000+ Posts Shoji's Avatar
    Jan 2012
    Mandurah WA
    1,193
    ROFL.
    Very dapper John. You match with your car well!
    ďListen very carefully, I shall say this only once.Ē Cheers. John
