EW10J4RS build - Page 3
Page 3 of 3 First 123
Results 51 to 72 of 72
Like Tree12Likes
Thread: EW10J4RS build
  1. #51
    Oct 2003
    608
    Have you wired the shield to B16?
  2. #52
    Fellow Frogger! Brett's Avatar
    Nov 2001
    610
    Motec loom so I assume they would have, but will need to check
    Bathurst______2 57.22 Sandown_______1 35.29
    Mallala_______1 22.90 Phillip Island____1 56.41
    Winton_______1.43.90 Collingrove_______38.08
    The Bend_____2 21.96
    https://www.facebook.com/FrogstompRacing/
    http://www.harlandeng.com.au
  3. #53
    Oct 2003
    608
    And why is your cam signal voltage over 8V? Makes no sense. Almost seems like the cam reference voltage has been wired off the same wires as the coil 12V+. It doesn't matter whether the loom is MoTeC or not, the person wiring it still has to do it correctly.
    (Ignore that. Didn't see this mornings graphs before posting.)
    Even post a pic of the wiring of the coils & cam sensor.
  4. #54
    7,358
    The cam reference is 8V, isn't it? ie 20-12=8
    I'm not sure adding the pull up resistor will make any difference in your case. ie you have a definite 0-8V square wave, it's just the interference which needs to be removed.
    thatguy likes this.
  5. #55
    1,540
    Use a shielded cable earthed (grounded) at one end only to prevent earth loops. Peters technique of going over gearbox moves it away from interference source.
    Or am I completely wrong as usual?
    Thanks, I read above Bluey is saying the same as he is asking him to put the shield to pin B16 or whatever. Shield, coaxial, ground, earth gotta love engineering and its terms and acronyms.
    FIVEDOOR and PeterT like this.
    307 HDi wagon
    407 HDi wagon
  6. #56
    Nov 2001
    610
    Rerouted cable no change
    We checked at the sensor and spikes are in the 8v supply
  7. #57
    Nov 2001
    610
    Spikes aren't affecting sync so it is running well.
    FIVEDOOR likes this.
  8. #58
    1,540
    OK, how high are the spikes and what is supplying the 8V, my recommendation is to fit a good quality electrolytic cap to smooth out these spikes and make you a happy camper.
    Alternatively if they are extremely quick spikes then a bypass cap wiill suffice, same problem is found when feeding IC's.
    307 HDi wagon
    407 HDi wagon
  9. #59
    Oct 2003
    608
    129.2Kw! That's more like it.
    Out of interest, what ignition module & coils are you running?
  10. #60
    Nov 2001
    610
    LS1 coil packs
  11. #61
    Nov 2001
    610
    Next problem to solve is oil accumulation and over flow of catch can.
  12. #62
    Oct 2003
    608
    Does the EW10J4S have a vacuum pump?
  13. #63
    Nov 2001
    610
    Electric pump but it is currently removed from the car.
  14. #64
    Oct 2003
    608
    Well, if you don't have an uncapped mechanical vacuum pump pressurising the sump then the only other source of pressure can come from the combustion chamber, i.e. blowby.
    Make sure you aren't running the oil level above the dipstick. I wouldn't be running a drainback catch can on a race car. You shouldn't need to drain back any oil vapour from the cam covers.
  15. #65
    880
    Where is the vacuum pump on the stock engine? I didn't think there was one.
    Point remains there is plenty of blow by pressure building up.
    1984 505 Executive Auto
    206 GTi 180 - '804 Cat Cams, Jenvey DBW 48mm ITB's, Emtron KV8 ECU, HP Electronik PDM, AIM MXS Dash, Custom Wiring Harness. AST Camber Tops & Coilovers, -2deg camber hubs by Frogstomp Racing, 24mm Torsion Bars, AP Racing brakes, PeugeotSport Baffled Sump, Oil cooler, Quaife LSD, E85.
    Sandown - 1:31.5
    Winton - 1:40.2
    Wakefield - 1:13.5
    Phillip Island - 1:55.9
    Previously, 2x 504 Wagon, 505 Wagon, 505 STi, 405.
  16. #66
    Nov 2001
    610
    Vacuum pump is mounted in front of lefthand side front wheel
  17. #67
    880
    I thought that was an air injection, not vacuum pump. An emissions helper for cold start?
    Sandown - 1:31.5
    Winton - 1:40.2
    Wakefield - 1:13.5
  18. #68
    7,358
    Many years ago on my first 205 track car, I thought I could plumb the oil breather system better than Peugeot. At the dyno it filled the 1L catch can. I found a 3L pineapple juice tin which I thought would improve things, but it too soon filled up. I went back to the standard setup and just ran a breather off the filler cap. Never had another problem.
    I'm not suggesting your car has the same issue, but given the broad and good power band it has, I doubt it has blow-by issues.
  19. #69
    NSW
    616
    I had to get my catch can to drain back to the sump. Only way it worked
  20. #70
    Nov 2001
    610
    Having spent the morning examining the stuffed head and standard intake manifold several discoveries have been made.
    What I thought were the front cam cover drains, aren't drains but sump breathers.
    These vent via standard manifold and don't drain oil from head.
    These vents have been blocked by the TB's installation. TB's to be removed, drilled and tapped to add 8mm vent tubes.
    The lack of sump venting is causing additional back pressure on oil on the three exhaust side drains.
    thatguy likes this.
  21. #71
    Nov 2001
    610
    Emailed to the throttle body supplier and got this back
    This engine is a little odd on the breather system. We have another customer racing who has vented these ports, thinking it would cure the problem but still collects loads of oil. He’s rigged up a 2 catch can system where the first one returns to the drain at the sump. It also doesn’t help that the breather at the sump is submerged to the bottom pickup area. The dry sump will of course eliminate all of these woes.
  22. #72
    Oct 2003
    608
    Quote Originally Posted by Brett View Post
    .....The dry sump will of course eliminate all of these woes.
    Well, that was a crap response.
    2 catch can setup makes sense though. It would be the same as what 205s & 405s have with their remote filler setup. The first can is basically a swirl pot while the second collects all the vapour. First can would need baffles to separate the oil properly. Only the second can would have to be 2L to comply with CAMS regs.
