206 electrical gremlins
Results 1 to 7 of 7
Like Tree2Likes
Thread: 206 electrical gremlins
    Nov 2016
    Sth Highlands
    3
    Default 206 electrical gremlins
    Problem #1 indicators only work when the headlights are on: why
    Problem #2 hazard and rear tail lights alternate flashing?
    Problem #3 when the second turn on the headlight stalk is turned on, the horn sounds ?
    can all these be linked to a bad switch module or a poor earth........
    worthy suggestions will be appreciated
    COL
    COL is online now
    A110 COL's Avatar
    Van Diemen's Land
    4,331
    At a guess I would say it could be bad earths that will need to be cleaned.
    And yes the switch could be faulty, if the switch does not feel positive in its movements I would suspect it.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    Fellow Frogger! Roland's Avatar
    Perth
    727
    Quote Originally Posted by Black206GTI View Post
    Answer - probably YES - sounds like the "Comm 2000" unit which is the device that all the control arms under the steering wheel are connected to.
    Land Rover Discovery 4
    406 Coupe D9 - Manual (2002)
    307 Hdi Estate - Auto - (2007)
    307 Hdi Sedan - Auto - (2007)
    505GR Estate - Personal Import from UK 1971cc Manual (March 1986)
    405 Mi16x4 (all the parts ready to install into the LeMans body)
    Sep 2003
    North Parramatta
    4,025
    +1 — COM2000 module.
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    Aug 2016
    Sunshine Coast, QLD
    949
    Does it have a floppy light control stalk? I think this is a common fault but not sure 206 has the same setup as 307?
    Sent from my GT-I9195T using aussiefrogs mobile app
    1000+ Posts cav91's Avatar
    Romsey, VIC
    2,350
    Another plus one for the com 2000. But also I'd check the earth in the taillights. Very common to go bad. That should be the alternate flickering
    2017 Renault Koleos auto
    Nov 2016
    Sth Highlands
    3
    Thanks Chris et al. In discussions with Dave ( during a visit to Melbourne) Ive run a seperate earth from the light bulb holder and thats solved # 2...........
    now working on the stalks........
