205 GTI - Steering Column Question
Thread: 205 GTI - Steering Column Question
    Fellow Frogger! SilverGTi_6's Avatar
    Apr 2005
    865
    Default 205 GTI - Steering Column Question
    Afternoon all,
    The car has been running beautifully this year. I've almost clocked up 20k since purchase and loving it! The last month or so I've had a minor niggle that has been annoying me. There is been a very small amount of movement in the steering wheel when stationary (it can't be seen visually, but can be felt). It is most noticeable when the car is moving and feels like there is a very small amount of movement in the steering setup (even when going straight).
    Anyway, my mechanic has done some investigating and determined that there is a very small amount of play in the bush at the top of the steering column housing.
    It's definitely nothing major but I'd really like to get this sorted as it impacts the awesome steering feel of the car! Does anyone know if you can buy these bushes separately? Has anyone worked out an aftermarket replacement bush that would work? Or is replacement of the whole steering column and bushes required (assuming you can still buy these from Peugeot)?
    Thanks heaps for your advice.
    Ben
    Lotus Evora
    Peugeot 308 GTi 270
    Peugeot 308 GTi 250
    1966 Volvo 122s
    Previous
    Clio 182 Cup, Lotus Sport 111, C4 VTS, RCZ, 205 GTi, Volvo C30 T5-R, Honda S2000, 206 GTi180, Lotus Elise 111R, 205 GTi 6, Manual 406 coupe, 306 GTi 6, 405 MI16 (twice!), 505 GR
    1000+ Posts cam85's Avatar
    Nov 2003
    Bondi
    3,441
    Does he mean a joint in the column?
    I would check yourself its tie rods or the inner ball joint on the rack.
    If its in the column you will need a replacement section.
    I guess have someone help you hold a section of the column at a time to determine where it moves.
    94 205 Gti Classic #9
    91 205 Si
    87 205 GTi Race Car
    Apr 2005
    865
    Nah, not the join, just the bush that is in the mount at the top of the column.
    I've had both tie rods replaced since purchase and the rack is all good (just had it checked over also).
    You can feel it when sitting in the car and moving the wheel gently (not turning, but just holding the wheel in position). It is side to side movement more than up and down and only very minimal. Just enough to be annoying (to me)!
    Lotus Evora
    Peugeot 308 GTi 270
    Peugeot 308 GTi 250
    1966 Volvo 122s
    Previous
    Apr 2005
    865
    Sounds like it might be a steering column replacement job. No other solutions to just replace the bush that people have come across?
    Lotus Evora
    Peugeot 308 GTi 270
    Peugeot 308 GTi 250
    1966 Volvo 122s
    Previous
    1000+ Posts BIGRR's Avatar
    Feb 2006
    North Rocks, Sydney
    2,467
    My 504 developed play in the "nylon" bush after about 30 years. I pushed the bush out and wrapped a layer of newspaper around the outside diameter of the bush and pushed it back in!
    Ex - Railway Fitter.
    Present fleet:-
    Peugeot 93' 205 Gti 16v
    Peugeot 73' 504 Ti from new
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 72' 16TS from new
    Renault 69' 10
    Renault 71' 10s
    Renault 68' 10 from new
    "Be reasonable do it my way!"
