Removing Baked On Door Rubbers
    Jan 2013
    Geelong
    560
    Default Removing Baked On Door Rubbers
    Removing Baked On Door Rubbers-img_1973.jpgRemoving Baked On Door Rubbers-img_1974.jpg
    Between my 2 projects I have 6 doors that look like this.
    I'm waiting for a real hot day to leave them out in the sun before tackling the job.
    Does anyone know of any magical techniques or solvents to expedite the procedure?
    1949 Citroen Big 6
    1955 MGA1500
    1970 Peugeot 404 Utility
    1962 Renault Dauphine Gordini
    1950 Grey Fergie Tractor (Pending Resto Project)
    1000+ Posts driven's Avatar
    Apr 2005
    1,564
    Back to the Rubber Chemical resistance chart.
    Pick your rubber and look down the chart to see what dissolves/softens it
    Do a test area first
    Easy
    Rubber Chemical Resistance Chart, Rubber Compatibility Chart - Mykin Inc
    Jan 2013
    Geelong
    560
    Easy
    Thank you!
    Well going on the no. of 3's & 4's they get, it looks like acetone and/or toluene (GP thinners) is the go once I dig out what I can with heat & a plastic chisel.
    1949 Citroen Big 6
    1955 MGA1500
    1000+ Posts Shoji's Avatar
    Jan 2012
    Mandurah WA
    1,193
    Heat gun for stripping paint. They have settings these days. So you don't smoke yourself out. Either way what a horrible job. Maybe wear some nitrile gloves with those chemicals.
    19,214
    I'd try some orange oil solvent first. Not nearly as toxic as the Vocs listed.
    I noticed that some cabinet makers have changed from MEK as glue cleaner to orange oil solvent.
    Commonly sold in Oz as Sceney's citrus solvent. And available at art supply houses.
    Jan 2013
    Geelong
    560
    Removing Baked On Door Rubbers-img_1975.jpgRemoving Baked On Door Rubbers-img_1976.jpg
    Hot air gun till the rubber starts to drip.
    Plastic chisel to scrape off as much as possible.
    Dremel with wire brush.
    Brush/wash with lots of Prepsol & wipe clean
    Crappy job!
    1949 Citroen Big 6
    1955 MGA1500
