Freeing frozen fasteners.
Results 1 to 20 of 20
Like Tree8Likes
Thread: Freeing frozen fasteners.
    16,749
    Default Freeing frozen fasteners.
    Using an old candle .... everyone has one of these around the house right ?
    I have a completely frozen brake mechanism here ... 30 seconds with a torch .... melt a bit of candle wax on it and ... I'll be dammed if it didn't all move when tapped with a hammer, then come apart.
    I have a two frozen 3 point linkage adjustment rods too.... They are probably threaded rod into tube 3" deep. No doubt they haven't moved in 3 decades. I melted some wax down into one of them, and it creaked and groaned.... and actually moved ( sheering off 1/2cm down into the sleeve). You know I reckon if I cycle the other one hot/cold a few dozen times, I'll get the wax down the full length of the threaded rod, and it'll move.
    This is absolutely amazing. You don't even need an oxy set. Just a small gas torch and a candle.
    6,665
    I saw that elsewhere and thought bs, but it's good you've confirmed it works!
    2003 PEUGEOT 206 GTi
    1000+ Posts BIGRR's Avatar
    Feb 2006
    North Rocks, Sydney
    2,467
    At High School (1964'ish), the Science Master drove a rust bucket '48 FX Holden. The chrome work was fantastic. The teach told us that when new he had painted all the chrome work with hot melted candle wax.
    Present fleet:-
    Peugeot 93' 205 Gti 16v
    Peugeot 73' 504 Ti from new
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 72' 16TS from new
    Renault 69' 10
    Renault 71' 10s
    Renault 68' 10 from new
    "Be reasonable do it my way!"
    Banned
    sydney, australia
    11,301
    it also goes well dripped on your bare ass.
    but only when tied to beam! but you all knew that anyway.
    nuff sed about the candle....
    more seriously.... great idea and i love the guy's accent and general mode of speech!
    highly entertaining...
    9,319
    Geez, Al...
    ACHTUNG ALLES LOOKENPEEPERS
    Oct 2005
    vic
    868
    Surely application of the torch did the majority of the work?
    Tell me he tried heat before waxing?
    The wax provided lubrication, could have been provided by any wick in penetrant?
    16,749
    It's only a little gas torch that I'm using ( You know ... $35buck from bunnings and a disposable bottle). I'll upload a couple of photos of what I undid tonight. The only way I could have got it apart without the wax was an angle grinder with a cutting blade.
    The wax seems to wick down threads when heated. In a way that all the fancy named "penetrates" such as wd40 etc... don't. To use heat to free up seized items, you would need an oxy set so you could get the item red'ish hot.
    What I've been freeing up is the brake on an old tractor that are enclosed in a "dry" housing on the side of the tractor. They sit in there and rust together in a most spectacular fashion.
    seeya
    Banned
    sydney, australia
    11,301
    Quote Originally Posted by 85Fuego View Post
    that is what i have been wondering too.
    i have seen a similar vid recently, so the idea must be doing the rounds.
    i note in this one that the comparison is with applying a penetant to the stud over time but without heat. so perhaps, as you say, heat plus a wide range of penetrants would do the same? even if so, however, combining heat with anything at all to wick in, is a noteworthy idea.
    16,749
    Try it .... what is there to loose ? Your talking a candle that is probably worth about 25cents ..... And a small gas torch.... I've never ( ever ) found penetrants of any sort actually work and "penetrating" and freeing frozen fasteners. They do lubricate and allow them to be unscrewed if you manage to break the hold of the rust without sheering the fastener though.
    seeya
    Oct 2014
    Windsor 2756 NSW Australia
    660
    seeya
    I agree, one way to bust a myth is to leave the keyboard discussion and actually do the experiment.
    Cheers.
    9,319
    seeya
    Not to say this isn't a neat trick, but I have found penetrating fluids work.
    Brake fluid penetrates, Freeze and Release (by Loctite) worked for me to extract a broken head bolt off a 205GTI block (just 1cm above the block, and people with 205GTIs know the pain), WD40 works as well. They may not completely release fasteners but they do help. One crucial aspect is patience. A broken head bolt in a Toyota cast iron block took me a week of soaking with brake fluid to release.
    Freeze and release worked practically instantly but I think I had the advantage of the bolt having some clearance around it in the hole where the fluid could penetrate and sit whilst evaporating, which cooled the bolt down efficiently. They claim the stuff also penetrates and lubricates.
    6,665
    16,749
    here's the brake rotors.... they are stationary. The brake discs spin on the spline line a clutch plate.
    the idea is a rod pushes on the mechanism, and the rotors rotate and press outward. It's completely seized.
    this is one of the nuts. There's nothing left there to grab as it's rusted away ( yes, nut, thats the remains of the bolt passing through it).
    this is all 100% frozen and locked up. You can hit it with heavy hammers and all you do it bend/break/damage it, but not break the corrosion.
    10 minutes iwth the torch and candle. First I grabbed the rusted away nut with some vice grips, melted wax down into it and hit the other sidie with the rattle gun ( both ends). Then with the bracket removed. I put it in the vice, and heated it all with the torch and melted wax down into the pin area, then gently tapped all the "legs" until they freed up and moved around. I could then break the split pins off and tap the pin out.
    100% disassembled. I'll sandblast it all... maybe give the rotors a touch up in the lathe and re-assemble with anti-seize paste.
    Attached Thumbnails Attached Thumbnails Freeing frozen fasteners.-p1180958.jpg   Freeing frozen fasteners.-p1180957.jpg   Freeing frozen fasteners.-p1180956.jpg   Freeing frozen fasteners.-p1180955.jpg   Freeing frozen fasteners.-p1180954.jpg   Freeing frozen fasteners.-p1180953.jpg
    BVH Roger Wilkinson's Avatar
    Warrnambool
    2,412
    Gee, Shane, they were bad! Mine have never been anywhere near that bad.
    If you ever get into real trouble with it there is always Jason Taylor at Stoneyford Tractor Wreckers. He would have a few.
    Roger
    1000+ Posts driven's Avatar
    Apr 2005
    1,565
    Frozen bolts, nuts get some
    Chemsearch YIELD. Costs heap but is 100% effective
    Yield
    I have no connection with the company
    16,749
    Roger
    The brakes match the rest of the tractor .... battered and well used It lived on a very steep hill where I bought it from ... I'd say they seized up "on" and the tractor was just continued to be used. As you can see they are heavily worn.. the entire mechanism really should be replaced... both outer brake pad discs had disintegrated.
    When it seized up only the outer half must "sort of" work. Amazingly there was slight retardation still if you stood on the brakes. I'll re-assemble the best of the crap bits and refit the diff lock side brake unit (as that side has a ballasted tyre) ... and chase up new parts and pads for the other side when I can find them. After all, it's never going to get out of low range around my place.... Having usable brakes on just one wheel is going to save lots of fence mending practice. (the last owner just crawled all over his vineyard in low 1st so he could just point it across the hill to stop ).
    Oct 2005
    Rome
    2,660
    Yes, I was wondering why Shane took credit for JBN's Toad Pond post made a week previously?
    Dave
    ​1997 BMW K1200RS
    IR655
    16,749
    Quote Originally Posted by 68 404 View Post
    Dave
    I stumbled across this when I googled "freeing rusted fasteners". I didn't realise it had already been posted!
    Dec 2004
    Devonport Tas.
    354
    Hi Folks
    Well, the candle trick definitely works, thanks Shane, I had to remove a stud from an old exhaust manifold, tried the usual sprays, would not move, heated it up, applied a candle to it and it came undone really easy.
    Regards
    Neil
    Perth WA
    94
    great tips and experiments!
    I had an ordeal recently when trying to remove a wingnut from the top of a 100yr old jewellers lamp shade.
    The wingnut was not original and i later found out it had different thread (as well as being fused to the thread...)
    After repetitive spraying over a few days with "rost off" imo an excellent penetrant for mildly rusted parts (certainly better than wd-40 & crc etc)
    I eventually heated it up with my soldering iron torch, then sprayed it with some freeze spray and I instantly heard a crack. The wingnut then removed with little resistance
    Nothing as major as the tractor part! that is a fantastic fix, but another method which i was very happy with
    89 Pug 405 Mi16
    Possibly for sale....
    WRECKING/ Parts Car:
    Blue 89 405 Mi16
