3 cylinder gs
Results 1 to 17 of 17
Like Tree7Likes
Thread: 3 cylinder gs
    Jan 2011
    adelaide
    154
    Default 3 cylinder gs
    Rear left (no2???) Being lazy. Has spark . New leads, new plugs, just refuses to help rest of engine. does seem to be very light on fuel in cylinder. Any one have any ideas .
    Newcastle
    2,800
    Hi tassy,
    The most sensible thing to do is to test the compression. You might even do a simple hold a piece of rounded dowell or similar in the plug hole and compare it to a good cyl if you do not have a gauge.
    Another suggestion if no gauge is to turn the engine over by hand and see how the 4 cylinders feel for a comparison of the compression.
    Poor compression, then check tappets, head tightness ?? Or some other thing worse.
    Jaahn
    Armidale
    2,599
    Assuming your engine has a single carby, then the only reason for one cylinder to use less fuel than the others will be lack of compression - this will reduce it's ability to suck in fuel/air mixture as piston goes down...
    Alec
    Perth Western Australia
    2,705
    tazzy,
    Inlet manifold gasket leak on offending cylinder.
    Valve seat recession. Can be picked up by zero valve clearance on same.
    CitroŽn Tragic UFO's Avatar
    9,810
    Give it a stern talking to and tell it to pull itself together.
    Jan 2011
    adelaide
    154
    Gave her a new carby, new plugs ,new leads, forgot about the stern talking to, unfortunatelly i don't speak french.
    11,302
    Did that work?
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    2,705
    tazzy,
    "Gave her a new carby ?" After a bit of a headscratch I recalled a 404 having a one cylinder miss. Turned out to be a badly worn throttle shaft on its Solex 34 pbic. This caused the fuel mixture distribution to be non existant on the faulty cylinder.
    Located by 'jiggling' the throttle shaft.
    1000+ Posts FIVEDOOR's Avatar
    Jun 2011
    Brisbane Qld
    21,054
    The "sophisticated" diagnosis is always the best
    Every day is a good day
    2,705
    tazzy,
    ..and the good news is ?
    2,705
    tazzy,
    Jan 2011
    adelaide
    154
    tazzy,
    decided to rebuild one of the heads i have laying around and replace the head completely as i will need to wait for parts could take a little time reporting further, thank you all for your concern will let you when she is up and running again.
    Newcastle
    2,800
    Hi tazzy,
    Your plan may be a good one, but over the years I have found it is always good to actually diagnose the problem. If you do not, then you run the risk of finding the problem is still there after you replace the head. BUGGER Just saying from experience !
    Jaahn
    Jan 2011
    adelaide
    154
    I agree and in saying so have done a dry compression test and came up 150 across all 4 cylinders, will follow up with a wet test just to see. Have ordered new dizzy cap and coil. So having a little bit off fun tracking down her problems.
    Los Angeles, CA USA
    1,955
    150 is plenty high. Per chance is the timing belt a tooth off? Don't ask me how I know to ask this.
    Do the dance. Do the Daffyduck dance using the Aussiefrogs app. Be real happy if you can.
    Newcastle
    2,800
    Hi
    Yes 150 is ok and if even between the 4 then the problem is not there !
    If you suspect the spark is the problem then the quick answer is to do a check in the dark. Start it and get under the bonnet and give it a full throttle blip, to load the engine for an instant. Not high revs but full throttle required for a second. Repeat as you look at the different parts. So do it where it will not annoy the neighbours
    Observe the ignition leads, boots, dissy cap and coil while you do this. Any breakdown in the insulation will be accompanied by flashes of spark leaking away to the closest metal. You might be surprised how many leaks you see. Use a mirror if necessary. 3 hands is "handy"
    jaahn
    2,705
    tazzy,
    Another one from my past, [got a million of 'em].
    Case one. 4 cyl Volvo B20 missfire. Compression test showed all equal and good. Found to be very badly worn cam and follower.
    Inlet valve was opening, just, allowing the compression reading OK at cranking speed. A different kettle of fish with the engine running.
    We need a camshaft guy to explain this better than yrs trly.
    Case two. Volvo B21 E. missfire. comp. tests etc OK. Turned out to be a broken valve spring.
    This is the part of the trade that I've missed. You can stick your ECU's
