Air Filters
Results 1 to 3 of 3
Thread: Air Filters
    1000+ Posts David Shearer's Avatar
    Glenroy
    1,141
    Default Air Filters
    Hi there,
    Just wanting to know all there is to know about air filters. I keep hearing they give "that much more" power and don't really know how. Are they relatively cheap to put in place. I have a 88 Mi16 and like the sound of a louder, more powerful car for a small cost.
    thanks for your help.
    Dave
    78 Fiat X1/9, Peugeot 406 ST, Peugeot 407 V6 SW
    Previous:
    05 Megane Turbo
    2x 89 405 Mi16
    67 404
    Peugeot, Francais pour "Putain qu'c'est vite"[/FONT]
    NSW
    1,063
    Don't waste your money. You will see NO improvement in power by simply replacing the filter. If you use something like a K&N flat panel filter in the standard air box you will get a louder induction note but thats it.
    The only time you MAY see an improvement is when you get a better flow of cold air into the engine. In this case its not actually the filter making the difference but the better, cooler air.
    Don't be misled by all the FALSE hype on filters.
    Jun 2003
    270
    ok if you got the cash, one of the best in my opinion is the BMC carbon fibre tube filter... its an enclosed pod filter with two openings, one for the inlet manifold and one for flexible ducting that leads to the front of the car, supply'n fresh air only... this costs about $250, but is worth it
    a good replacement panel filter like a K&N is the next best thing, try this out... i think about $120
    Worst of the bunch are the open pod filters that suck up hot air from your engine bay.... dont get any that cost more than $30, they're not worth any more than that, all of them nomatter the cost are the same ( maybe 1kw difference) and they make you lose power unless they are perfectly sealed off from the engine bay's hot air
    do yourself a favour and make it easy by getting one of the BMC ones as per above, it will make life much easier and give you a great sounding car
    like daz said, its not the filter (they're all the same) its the quality of air being supplied... i dyno tested about 5 different filters last time i built my engine, and there was no difference between a $25 simota pod filter and a $350 HKS filter....
    Peugeot 306, garrett GT25 turbo, 3" exhaust, microtech LT8 ECU, 16.7 psi, front mount cooler, Chris Milton race port&polish w/ 3 angle cut valves and redesigned combustion chamber, 186hp atw for now... injectors ran out of puff
    NOS COMING SOON!
