vacuum bypass valve
Results 1 to 3 of 3
    Member GTi - 666's Avatar
    Springwood
    39
    Default vacuum bypass valve
    i have noticed on my gti6 that when the vacuum line comes of the fuel reg the car fuels up to the point of missfiring on light throttle but goes like the clappers up top.
    thoughts/suggestion on putting a bypas valbe in hooked up to a switch in the cab, off all good nice cruising, flick the switch and we are in race mode
    Dec 2002
    2,528
    Theoretically, if the system is working properly, when you are full throttle there should be minimal vaccum (usually absolutely zero) in the intake manifold... so when you are at full throttle on full load, the fuel pressure regulator is operating exactly the same as it would be if you just pulled the hose off. The only difference you're making is to over fuel the car on low loads and at idle, which the computer, via the EGO sensor, will try to overcome anyway. Overall benefits? None. If the engine does in fact go better up high with it disconnected, something is not right.
    Scotty
    Melbourne - Dandenong Ranges
    2014 Peugeot RCZ - 'Remy'
    Springwood
    39
    true true but i was thinking mor of the benefit of having the fuel reg already at full pressure when the throttle closed having the gas ready for the go. however i didnt think of the spaz the ecu would be having at that point.
