PEUGEOT 504 Wiper motor wiring
    Fellow Frogger! PCOATES505's Avatar
    Jun 2002
    Gunbower
    370
    Default PEUGEOT 504 Wiper motor wiring
    I am putting a 504 2 speed wiper motor in my 403, I need to understand how the park circuit works. It is a Bosch motor with 2 wires into the motor , green is low speed, red is high speed, then there is a brown wire and a black wire each connected to a contact that runs on the gear, the third contact is earthed.
    What needs to be powered or earthed to make it park?, do I need to bridge something to the low speed wire?
    Any help appreciated.
    Pete
    For information of those interested :-
    The body of the motor is connected to earth, Green wire is low speed, red wire is fast speed,. For the park circuit, if power is applied to the black wire, when in the park position nothing happens, if the motor has been rotated, then power comes out the brown wire, the third internal contact goes to earth when in the park position.
    So apply power to the green wire motor rotates slowly, apply power to the red wire motor rotates fast.
    If the motor is rotating then turned off, it stops in any position, if power is the applied to the black wire and the brown wire is connected to the green wire, the motor will park.
    I am gunna get another 403 on the road........one day
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,782
    You will probably need the wiper switch out of the 504 if you want to make things easy.
    Regards Col
    1995 Renault Laguna V6
    2002 Renault Laguna V6
    1973 Alpine A110
    1000+ Posts Beano's Avatar
    2,895
    My 2 cents worth : (And this may be all it's worth )
    All I know is that there is a large relay ( about 2 or 3 times the size of your usual automotive electrical relay) up under the dash, with "Mixo" written on it.....which I believe is a timer.
    And 505s have one with "temporisateur" (which I believe means "timer").
    1000+ Posts Shoji's Avatar
    Jan 2012
    Mandurah WA
    1,011
    Great info. this helped in my refurbishment of my wiper motor
