205 head difficulties
Results 1 to 9 of 9
    Tadpole garett205's Avatar
    22
    Default 205 head difficulties
    hey guys, i have a few questions i just cant get a straight answer out of any mechanics, i bought my 205 in october last year and i cant complain too much i love it too much, yet i noticed ever since i bought it i couldnt get it over 4000 rpm which worried me. i spoke to a mechanic and he said it was probably just my cat which may had been clogged with gunk, so it was replaced, that helped slightly,
    i do have a sparco cold air induction kit and an exhaust and i have noticed that since putting them on i can hear the engine a lot better (obviously) and it sounds like i am running 3 cylindars from about 2000rpm to about 3500 rpm then it smooths out and pushes to around 5200 rpm, i spoke to a different mechanic and he drove it and said that i could possibly have a shitty valve stem on my number 4 cylindar, we checked the compression and that cylindr was down a bit but not much for the kms.
    i guess my question is what is the worst possible scenario for me, i just want it to run well, is a head recondition going to help me?
    if so could i buy the parts etc?
    thanks!!!
    7,448
    Quote Originally Posted by garett205
    thanks!!!
    Valve stem seal failure is very common on these engines, but that will just result in smoke. It should still rev out nicely to 6000+. If all the cylinders have good compression (180 psi), it's more likely your cam timing is out by a tooth. Verify cam timing and compression before doing anything else (in that order).
    1000+ Posts Dave's Avatar
    Apr 2001
    1,340
    Does your 205 use much oil?
    Some of the Bx's i have seen (same engine) have badly polished bores. This makes them use a fair bit of oil, and also they dont feel very healthy when you give them full throttle. The problem could be that your getting a bit of blowby when the engine is under heavy load.
    Dave
    22
    yeh i think you may be on to something, the car runs on 3 and a half cylindars though, that is what worries me most. it is good up high but down low is shit, like it needs for the combustion to build up with the revs , maybe something is leaking
    22
    Quote Originally Posted by Dave
    Dave
    like most peugeots i have heard it uses a little oil, but it doesnt blow any smoke and i check the oil regularly and it is fine.
    22
    thanks
    http://www.peugeotperformance.net/gallery/205/garett205gti/garett205gti.html
    1000+ Posts Luca's Avatar
    Mar 2003
    1,335
    Could be something else guys follow me now.....
    Does it get noisey when u're revving it out?
    or
    Does it start to sound like a tractor (tak tak tak)?
    22
    Quote Originally Posted by Luca
    or
    the only noise it gets when revving it out is the induction noise, when the car is idleing, the tappets are quite noisey and it does sound a bit like a tractor,
    i am going to check my timing setups, if i had a broken valve stem wouldnt it fall into the piston cylindar??? also symtoms of cam timing sound similar to mine so i guess it will be a touch and go operation
    Tadpole Mi16's Avatar
    17
    thanks!!!
    You're a mexican bandit
