Lubricating 405 trailing arms
    Christchurch, NZ
    228
    Default Lubricating 405 trailing arms
    I know this is covering old ground, but I can't find it.
    I am sure I read some good detailed instructions on how to fit grease nipples to the rear end of a 405. This sounds a hell of a lot easier than rebuilding the whole thing.
    95 MI16
    71 404 U10 ute
    66 404 coupe
    55 203C (gently warmed) gone... sold...
    12,256
    Quote Originally Posted by kiwi 03
    click here kiwi for the info you were after
    regards
    the 'rambo
    1 x '98 306 GTi6
    Christchurch, NZ
    228
    regards
    the 'rambo
    Thanks for this. it tells me how to rebuild it, but waht I actualy need is info. on where to put some grease nipples to save myself from the rebuild somewhere futher down the track.
    203 for ever!!!
    95 MI16
    71 404 U10 ute
    66 404 coupe
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    Kiwi,
    I'll jump in here. I have a set of instructions for a BX 16V which I understand is so close to a Pug it's almost identical.
    http://www.aussiefrogs.com/snippets/grease.htm
    The thing to remember about this is that it doesn't lube the rear bearings as such. It actually fills a void that if in the course of operation these get hot, they will draw a lubricant (liqiuid from the grease) in rather than water as well as dterring moisture contamination.
    Many will argue that they don't work & never will, however I have seen cars that have done mega miles with this mod fitted that never have had a major problem with their swing arm bearings whilst others driving in similar climatic conditions declaring they need to do theire every 60 - 80,000 klms that have remained standard so I have little doubt it is a mod worth doing.
    The reason I explain about it not lubing is that often guys with swing arm bearings on teh way out decide to do this in the mistaken belief that it will prevent an inevitable job. It won't if the bearings are on teh way out. In that case I'd suggest doing the job and making sure the bearings are well coated in grease when reassembled, then fitting the mod; it should almost last forever.
    I trust it will be some help to you.
    Alan S
    Christchurch, NZ
    228
    Icon7
    Thanks Alan
    This is what I was looking for. The rear of the MI16 is fine, but I would rather try to keep it that way than wait until it gets wobbly and costs more than the car is worth to fix.
    Kiwi 03
    95 MI16
    71 404 U10 ute
    66 404 coupe
    8,923
    Kiwi,
    If ever you have one go on you, don't panic; they are a fairly simple job to do.
    First one takes about 1 1/2 to 2 hours; second side because you have all the tools, the experience & the job is fresh in your mind.....about 45 minutes.
    Kits (bearings, spacers & pre load washers) go around $80 a side.
    Alan S
