Turbocharging 16V
Results 1 to 25 of 41
    Member senthil16V's Avatar
    malaysia
    102
    Default Turbocharging 16V
    Dear Mates,
    Im from Malaysia and currently own a Citroen ZX 16V 1994....im contemplating to turbocharging my car....just wanna know whether you guys have turbocharged this engine previously....i would like to keep the costs low so im opting out for decompression plate to reduce compression ratio rather than using forged low comp pistons....any of you have done this? i want to run only about 6-8psi of boost to maintain the reliablitiy of my car....
    any suggestions? any websites where i can buy or turbo kit?
    if no are there any websites where i can obtain the turbo exhaust manifold for XU10J2 and Xu10J4 engines?
    Please provide me details where i can opt out to buy forged decomp pistons suitable for both these engines.
    Thank you.
    With Rgds,
    senthil16V
    Jun 2003
    270
    lol, everyone has been suckered into thinking that forged pistons are needed for turbos...
    simply put, they are not for road cars...
    if you want to replace them after about a year, no worries... but your best best is to machine some compression out of the head or get (i dont know how to spell them) hydrolautic pistons made with less sompression, which are stronger than standard but not as bad wearing as forged.
    as for boost 10psi with a decompressed engine would be no problems, but you would have to buy a stand aone ecu, maybe motec, if you want to turbocharge.
    wiseco or JE in america custom make pistons
    simple answer tho... if you are tight on money, you WILL blow your engine... changing atmo to turbo is very expensive, and even running low boost can easily blow you engine if you dont spend money on everything to go with it... budget for atleast AUD$13000 for anything decent, or you might be able to get a kit for around $7000
    Maybe try to find a better engine to fit in your car
    Peugeot 306, garrett GT25 turbo, 3" exhaust, microtech LT8 ECU, 16.7 psi, front mount cooler, Chris Milton race port&polish w/ 3 angle cut valves and redesigned combustion chamber, 186hp atw for now... injectors ran out of puff
    NOS COMING SOON!
    malaysia
    102
    Icon10
    Dear mate,
    Thanks for your suggestions....these are the following modifications that are being considered :
    a) Turbo manifold
    b) Garret T25 turbo (from SR 20DET)
    c) 10 row oil cooler
    d) Surface the cylinder head to make sure the surface is completely flat.
    e) Install de-compression plate to reduce engine compression ratio from
    10.4/1 to 8.9/1.
    f) Complete head gasket kit.
    g) 2 head gaskets will have to be installed between the plate.
    h) Replace the thermo fan switch to allow fan to come on at a earlier stage
    to keep the engine running cooler.
    i) Complete 2 ½ exhaust to allow the engine run efficient with the new turbo.
    j) Modify turbo intake as well as engine intake with mandrel bent stainless
    steel piping.
    k) Install hi-flow air filter element to allow sufficient air supply to the engine.
    l) Install hi performance full injection chip to increase full supply under
    acceleration and not to allow the engine to lean off.
    m) Replace fuel pump with a high flow unit together with an adjustable fuel
    regulator
    m) Replace ignition plugs and spark plugs with a colder range.
    I'll be running only 6 to 8 psi boost and expecting 50 - 60 bhp increase over the standard engine.
    If you guys are interested in the performance chip, its available over here for XU9J2, XU10J2 and XU10J4 engines. Its called Speedchip and from Germany.
    Current mods on my car :
    1) Full sebring exhaust system
    2) Custom made mandrel bent intake system
    3) Speedchip
    Kindly feecback on the above mentioned system
    Thank you.
    1000+ Posts Luca's Avatar
    Mar 2003
    1,335
    Sounds like u're trying 2 set the world on fire dude...
    NSW
    1,063
    Thats a pretty good setup actually on a budget.
    The only thing I would be doing is using a T28 rather than the T25. There may be a little more lag but the bigger turbo should be able to generate more power through greater air flow while also reducing inlet temps as it doesn't have to spin as hard. This is expecially the case without an intercooler which I did not see on your list.
    malaysia
    102
    Icon10
    Dear Mates,
    Thanks for your wonderful comments and suggestions....so you guys reckon that i go for T28 rather than a T25? Any idea what car uses this kinda of turbine? I chose the T25 because the availabilty in Malaysia....plus its got a intergral wastegate and water jacket for the bearing section.....very important in our soaring temperatures in Malaysia.....
    Any suggestions what approximate size intercooler i should use with T25 or T28?
    I got the design for the turbo manifold already....so kindly take a look and feedback to me....this manifold design can be used for XU10J2 and XU10J4 engines...
    With Rgds,
    Senthil16V
    NSW
    1,063
    Look at late model SR20DET's. Here in Oz they used the T28 on the S14 and then the S15, which I think is a ball bearing turbo. I could be wrong though. Either way, they still use an internal wastegate like a T25. The other option would be to use a T25G which is the ball bearing version of the T25. Of course, ball bearing turbos are always dearer than their non ball bearing brothers.
    As for the intercooler I would use the biggest one you can fit. You cannot go wrong with a big intercooler. Well you can, but very rarely.
    The manifold looks great. Another way you could do it cheaply is to use the standard header part with a turbo flange mounted on a piece of pipe bolted to the headers. It would look somewhat similar to the one in the picture but would be 2 piece instead of 1.
    malaysia
    102
    Icon14
    Dear MYT 205,
    I'll check that out and see with the local shops over here whether they have the s14 or s15 turbos...yes brilliant suggestion by using a adaptor flange...it is definately cheaper....my logic is that once you have got the exhaust manifold extractor future upgrades would be a breeze....this design also ensures that there is minimal flow restriction losses in the exhaust thus increasing power output and promoting better cooling for the turbocharger....the only shortcoming is the battery and the ECU needs to be shifted to the boot to accomodate the turbocharger....
    please refer to attachment to see location of turbocharger in this 205 pug Mi16 tubo....
    could you please provide me with some pictures of your car? very interested in seeing your conversions down under and sharing ideas to make our cars go faster!
    take care mate....
    With Rgds
    Senthil16V
    Attached Thumbnails Attached Thumbnails Turbocharging 16V-205mi16turbonew1.jpg
    Aug 2003
    38
    Ummm the SR20DET from the GTi-R(RNN-14) is also a T28, along with the PNW11(Avenir).
    Good luck dude
    Jun 2003
    270
    After 3 second-hand turbos, all from nissan GTI-Rs, had lost their seals and dumped all my oil into my exhaust, or otherwise been stuffed, thats one reason to buy a brand new garrett gt25 (a ball bearing t28)
    The ball bearings are new technology, compared to the 30yr old design of non-ball bearing
    it will set you back around $1700 for the new turbo, but its btter than wasting $900 on a second hand gt25 from a JDM s14 or s15 200sx
    as for the manifold, its a pretty good on, as it gives heaps of room for a t28, and easy routing of pipes and filter, its exactly the same as mine, if you wana see how your turbo will look with that manifold
    www.cardomain.com/id/turbopeugeot306
    As for "chipping" it, if you dont want your engine to blow, get a proper ecu
    NOS COMING SOON!
    malaysia
    102
    Icon14
    Dear turbopeugeot 306,
    Great work mate....car really looks devilsih....just a question....how come you got only 167bhp after doing so much of modifications?are you still using the standard pistons?
    the standard engine pumps out about 100 plus bhp....so you only got 50-60bhp after parting with so much cash? im sure with your mods you could easily exceeded 200 plus bhp....what went wrong mate?
    maybe should left the head standard without doing all the angle cutting and what not....the combustion chamber modifications is a highly sensitive job and demands high precision....a small mistake can lead to decrease in horsepower as in this case....why dont try to get another second hand head and see whether this will make a difference?
    if you need any help to source out the head give me a yell....can find second heads in malaysia...
    With Rgds,
    Senthil16V
    Mar 2003
    1,335
    http://www.cardomain.com/memberpage/258992
    looks like it's been done successfully.
    12,256
    Quote Originally Posted by Luca
    is that a diesel ??
    if not then why is the redline at just over 4500rpm ??
    just thought i'd ask as it seems strange otherwise
    1 x '98 306 GTi6
    Mar 2003
    1,335
    Dunno 'rambo... i'll email the guy and find out.
    Jun 2003
    270
    i dont know what you are talking about 167hp,
    its 185 hp at the wheels, thats a 250hp engine... alot of hp for a 1000kg car
    its on standard internals, and waiting for bigger injectors is the only thing holding back another 80 odd hp
    NOS COMING SOON!
    Fellow Frogger! Gak306's Avatar
    135
    Quote Originally Posted by turbopeugeot306
    This will be the 4th time I post this question. Do you think you can answer it this time??
    Have you ever run this car of yours over 400m?
    What was the time? Real time not your estimate like on the other web site.
    Mar 2003
    1,335
    It hasn't been run man.. that's why there's no answer.
    Dec 2002
    2,528
    It says on your website that you've got 125kW at the front wheels.... that's 167.6 hp. I'm guessing that's where he came up with that figure. Which dyno did you see 185 hp? Turbo Tune?
    Scotty
    Melbourne - Dandenong Ranges
    2014 Peugeot RCZ - 'Remy'
    uk
    2
    yo dudes..
    senthil16V what have you decided to do about the turbo?? are you still wanting to do it, because me and my friend are.. we both have zx16v's!
    any more news on this??
    rich from the uk
    malaysia
    102
    Hey painman,
    So whats the progress on ZX 16V man? So are using decompressed pistons or just using spacer plate? what boost are you running? any photos regarding your turbo conversions?
    what kinda of info you need man? let me know the list of things need...so we can network and do the conversions to make our cars to kill all those Honda Vtecs on the road!
    Take bro!
    With Rgds,
    Senthil16V
    With Rgds,
    Senthil16V
    malaysia
    102
    Icon14
    Hey richman,
    Take bro!
    With Rgds,
    Senthil16V
    With Rgds,
    Senthil16V
    uk
    2
    yeah sorry..
    we are just looking to turbo our cars but really dont know where to start! its either that or shove in an ZX 3.0l v6 engine!
    have you done anything to yours yet?
    cheers
    Jun 2003
    270
    push refresh then look at my page... along with the dyno chart showing 135kw atw...
    Im looking into having some gears made up to take the power increase of my 3rd engine build... we're aiming for 200kw atw this time
    But thats the reason i havnt run a 1/4, i dont want to blow this box before i get a stronger box, im not paying 4g's for a box when i will only use it for 6 months... but dont worry, end of the year the new engine and box will be ready to make some numbers on the strip...... so stay tuned
    NOS COMING SOON!
    malaysia
    102
    Icon14
    Dear Guys,
    I have not modded my car with a turbo yet....definately in the near future...so you guys have decided to go NA or turbo yet?
    You want further information of the kit you can refer to the mods that i want to carry out on my car...
    With Rgds,
    Senthil16V
    With Rgds,
    Senthil16V
    Jun 2003
    270
    if you can get the gear you listed above go for turbo
    actually.... go drive a type R integra, then go drive a turbo car w/ an intercooler and exhaust... make your decision after that
    NOS COMING SOON!
