who doe's a nice 205 cam?
Results 1 to 16 of 16
    Member pugly's Avatar
    adelaide
    98
    Icon5 who doe's a nice 205 cam?
    who does a good cam for the 205, i wan't it to be as good as it is to 6500rpm
    as it is to 4000rpm.
    when i go up against a 5 litre, i pull away in first(by a car length) but second is shit, they real me in, third gets better again
    i want an affordable cam
    if this can't be done then a turb is the only way
    NO 16v
    12,256
    Quote Originally Posted by pugly
    NO 16v
    so i take it your sole purpose for this car is traffic light grand prix's
    such a waste of a drivers car but anyway have a chat to Peter T and see what you can come up with
    1 x '98 306 GTi6
    Ipswich, Queensland.
    1,892
    The lack of performance after the change to second probably has more to do with the huge leap in ratio to that gear, where the rest of the ratios are good.
    X 205 Gti owner when they were new. The series 3s are OK. 1s and 2s are ordinary in the gearbox ratio dept.
    '56 Renault 750 (16TS Power)
    '62 Renault Dauphine Gordini
    '08 Renault Megane sedan
    1000+ Posts N5GTi6's Avatar
    1,093
    Quote Originally Posted by alan moore
    Isn't the only difference in a series 1 that first gear is shorter? Aren't the other ratios the same - correct me if I'm wrong.
    '07 C3 Exclusive
    '10 308 Sportium Touring
    '12 Megane RS265 8:08
    adelaide
    98
    Default yeh yeh
    Quote Originally Posted by N5GTi6
    ok guys, i just need to know who does a cheap cam or grind to get me over 4
    grand, the rest of the motor is already modded
    7,446
    What's the engine spec. so far?
    adelaide
    98
    Default mods
    head ported & skimmed 1.5mm
    new 2" exhaust with no cat
    moved afm so k&n pod is in the battery position
    where can i get a cam to increase performance to 7000 rpm, i'm in adelaide
    want to pay less than $400, anything more than this and the turbo is the only way to go
    NSW
    1,063
    Explain to me how this can be so???
    adelaide
    98
    Default $800
    Quote Originally Posted by MYT205
    rb20 gt25= $200
    malpassi rising rate fuel regulator= $230
    steam bends= $50
    donuts, straight pipe= $200
    welded up truck cooler= $70
    bosch blv=$50
    silicon hose= $60
    other little stuff (argon,rodsetc) $100
    so say about a grand for a turbo
    i therefore only want to pay under $400 for just a cam, its not worth while paying any more for the extra performance
    Dec 2002
    119
    pugly,
    i sent you a private message regarding supercharging the early xu9j1z 8V motor (8.4:1 compression) as opposed to turbocharging...
    1000+ Posts Warwick's Avatar
    Nov 2002
    2,664
    What'd you do to fix the valve timing after skimming the head so much? Or is the timing out something shocking.
    Um... Go a 162B grind at Wades in Melbourne. $360 from memory, plus courier. Requires valve springs too. Easy.
    Then again you could put a turbo on.
    Just like that.
    "Hey Clem, what's that sitting on top of your sisters stomach?"
    "That's a turboo Cletus. Yup a turboo."
    "Well put it in that Poo-Jet over there, you know, the one by my grandpappy."
    "I did that Cletus. Got any woood so I can whittle some. "
    Or you could do the difficult thing an get the cam ground.
    adelaide
    98
    Default what comp
    Quote Originally Posted by Warwick2
    Just like that.
    smarty pants, what comp u running with the cam?
    what rpm is it good for?
    Nov 2002
    2,664
    I think it was something like 11.2:1, and was decompressed by a thick Head gasket to about 10.6:1. Can't remember exactly.
    It was a grouse cam, cos it was torquey, and it revved well. But I didn't change the rev limit. SO it went to 6200 rpm or something.
    1000+ Posts Luca's Avatar
    Mar 2003
    1,335
    Dude i can put u on 2 a guy who has some cams already done 4 the 205.
    If your interested chill out a bit in the forum and PM me...
    adelaide
    98
    i'm confused, people recommend running the cam profile like the uk spec 130hp, for i've got approx the same comp ratio (9.5:1 at the best)
    but what cams are these guys in the uk putting in their stock comp cars?
    ive been told not to go for a hotter profile due to not having a high enough comp????????????????????????????????????
    lumpy mmm?
    I like whipping my 205 around almost as much as I like whipping my RM250 through the air (you don't know your limits untill you have been past them)
    7,446
    lumpy mmm?
    Have a look the first 205 cam from www.pipercams.co.uk, the P16BP270. They recommend a 28 thou skim off the UK head, which is already 9.5:1.
