Engine bracing
Results 1 to 23 of 23
Thread: Engine bracing
    Jun 2003
    270
    Default Engine bracing
    What is the best way of bracing an engine from torquing too much?
    To use an engine-to-chassis brace or to fit much stiffer engine mount bushes?
    Peugeot 306, garrett GT25 turbo, 3" exhaust, microtech LT8 ECU, 16.7 psi, front mount cooler, Chris Milton race port&polish w/ 3 angle cut valves and redesigned combustion chamber, 186hp atw for now... injectors ran out of puff
    NOS COMING SOON!
    Fellow Frogger! winnie's Avatar
    123
    Quote Originally Posted by turbopeugeot306
    I am assuming the pug engine is not a stressed member and therefore should not be used as one, so i would go for stiffer/stronger bushes.
    Besides the engine mods (impressize power btw) what else have you done?? and what do you want from the car ie primarily straight line?? Just curious.
    Dec 2002
    119
    fit solid bushes - available from pugspares.co.uk. 205/306/309/405 they're all the same bush!
    2000+ Brad's Avatar
    2,404
    Gaffa tape its mouth.
    Sorry, couldn't help myself.
    Jun 2003
    270
    lol, nice one Brad
    Winnie, go to www.cardomain.com/id/turbopeugeot306
    Too long to list
    As for what i want out of it,
    a little bit better on corners (some swaybars and strut brace)
    A little more stopping power, im trying to find out what brakes from other cars i can fit
    And finally to have some thrilling straight line power... need to find some injectors
    I need to find out how the hell to get the 306 wide body kit over here....
    After that im happy
    NOS COMING SOON!
    123
    LSD if you don't have one already might be nice to squeeze into the budget.
    Upspeced shocks are good but it is probably worth the effort to put some quality stiffer springs in it also. Stiffer isn't always better, but i'm pretty confident wouldn't have limited their market by putting a harsh / less compromising setup in their factory standard.
    12,256
    lol, nice one Brad
    Too long to list
    After that im happy
    sounds like you need either a GTi-6 or S16 front end in the car
    1 x '98 306 GTi6
    7,446
    You need one of these. $150 + P&P. That includes pressing of the new bush into the bracket.
    Dec 2002
    119
    Or you can just buy the bush and have your local mechanic press it in for you with a hydraulic ram and silicone spray (lubricant) for free.
    $150 is a bit pricey...
    1,160
    Quote Originally Posted by Brad
    Hmmm not funny & you're also not very australian...
    USE ZIP TIES!!!!
    Lol... ha ha haaaa
    7,446
    Quote Originally Posted by 205 GTI16
    Good luck then. When you factor in tooling costs to get the mould made, travel time, time off the road, time getting it pressed in/out (if someone does this for free).......
    Jun 2003
    270
    PeterT, can you get a hold of them, or know of a place where i can get them in Australia, otherwise i have to get them from the UK site
    They have a rally group-n and group-a mount kits.... which one, as i need it stiff but its still a road car
    NOS COMING SOON!
    Jun 2003
    270
    So pete whats the difference between the ones you showed and these?
    NOS COMING SOON!
    Jun 2003
    270
    Oh, and is it possible to unbolt the engine and leave everything connected, just slipping these under and bolting on?
    NOS COMING SOON!
    7,446
    Not much. Mine are a fraction harder. I can only supply the bottom and top right mounts though. They're not hard to replace if you do them one at a time. The RH driveshaft needs to be removed, and gearbox oil drained, to replace the bottom mount. The engine needs to be support with a jack to do the other two.
    May 2001
    Sydney, NSW, Australia
    3,626
    Shove a sock in its mouth
    Derek
    sorry, I couldn't resist!
    Jun 2003
    270
    So do i need any other mounts or are the bottom and top right mounts good to do the job?
    So the engine just needs to be hung in an engine crane? Nothing other than the RH driveshaft needs to be removed?
    Whats with draining the gearbox oil and whats a good replacement oil?
    NOS COMING SOON!
    7,446
    [QUOTE=turbopeugeot306]
    So do i need any other mounts or are the bottom and top right mounts good to do the job? That's all you need. Those two work the hardest.
    So the engine just needs to be hung in an engine crane? No, just jack it up underneath with a trolley jack (or similar). No jacking required for the bottom mount. The motor will swing/hang on the other two mounts.
    Nothing other than the RH driveshaft needs to be removed? Correct, but you'll need big tools to undo the axle nut.
    The oil drains on to the floor when you remove the shaft. Drain into a clean bucket then tip it back in.
    Jun 2003
    270
    Thats what i love about aussiefrogs, you cant get good info. like that everywhere
    Cheers pete
    So how much do you want for them posted to Adelaide, and how soon?
    NOS COMING SOON!
    7,446
    Cheers pete
    Bottom one is available now, I'll have to check on the top. Probably mid next week. I'll get back to you with firm prices and dates.
    You'll need to send me your bottom and top mounts after, whether they're in pieces or not.
    Jun 2003
    270
    No probs, post the prices and details on here asap
    NOS COMING SOON!
    Dec 2002
    119
    Thats what i love about aussiefrogs, you cant get good info like that everywhere
    Actually, most people who work on their Pugs could have told you that.
    That info is one of the first things you'd learn if you had read the Haynes manual for your 306. The manuals only cost about AUD$50 and I personally recommend every owner of 205, 306, 405 etc buy one!
    Dec 2002
    119
    PeterT might respond quicker if you say "please"...
