torque conversion
    12,256
    Default torque conversion
    ok heres one that i have searched high and low for and have never seem to be able to get an answer
    how does one convert m.daN (m.kg) to lb.ft or Nm ???
    the closest i have found which is still way off is kg/m to lb.ft which is 7.236
    that should get a few books out and people thinking
    1 x '98 306 GTi6
    1,160
    Fellow Frogger! winnie's Avatar
    123
    kg's and lb's are measures of mass not force and shouldn't 'strictly speaking' have been used in a relationship to describe a torque. A Torque is a rotary force, to get a force from a mass it must be accelerated. Acceleration due to gravity is ~10m/s/s (9.81 but i'm not going to get too precise because it actually varies slightly depending on your proximity to the equator) Rant over
    From primary units (the conversions of these have some inaccuracy)
    1kg = 9.81N 1m.kg = 9.81Nm
    1kg = 2.2lb & 1m = 3.281ft 1m.kg = 2.2*3.281=7.2182lbft
    A little rough but if your not putting a man on the moon these should get you by.
    9,223
    You could always read it off the scale on torque wrenches with both measures...
    12,256
    and would you believe it the Snap-on man went through all that and still couldn't find it either
    so even with the info so far as this is for head bolt tension at 4.5m.daN that means 32.5 ft.lb torque
    1 x '98 306 GTi6
