Brakes GTi6
Results 1 to 7 of 7
Thread: Brakes GTi6
    Member Cookie's Avatar
    Sep 2003
    31
    Default Brakes GTi6
    My 6 has a definate shudder when braking. It appears worse when braking from 100klm+. Has anyone encountered this or am I just s*it out of luck.
    If a rotor is warped can anyone suggest a good repairer in the southern Sydney area. Alternatively does anyone know the approx price and where to get aftermarket rotors?
    Thank's.
    Dec 2002
    119
    Quote Originally Posted by Cookie
    Thank's.
    i'm not sure about gti6 discs (rotors as you call them) but Peugeot genuine 205 GTI discs are only $200 a pair - that's $100 each. you won't beat that with aftermarket...
    go speak to peugeot first about genuine gti6 replacements- alot less time consuming than researching the aftermarket...
    12,256
    try this link here
    brad put some effort into this not so long ago
    306 Brake Upgrade Thread
    1 x '98 306 GTi6
    Sep 2003
    31
    Ok, thanks guy's the info is very helpful. I will make some calls and see where it leads me.
    1000+ Posts tekkie's Avatar
    Jun 2002
    1,516
    Cookie, what pads are you using?
    The warping can happen when you fang the car for a while and stop it and sit on the brakes while they are cooling, or when you have hot brakes and go though the water. The latter rarely happens.
    The thinner the brake pad material more often the warping effect is prone to happen. Also.... some brake pads exibit greater resin transfer onto the rotor to others.
    Sep 2003
    31
    Hi Tekkie,
    I dont know what pads they are as they were on the car when I got it. I am assuming they are standard.
    What you said about thin pads makes sense as the pad wear warning light has been on for about 2 weeks. Hopefully this could be the cause of the shuddering.
    Can you suggest a good replacement pad and where to get them? I am toying with the idea of aftermarket slotted rotors. I don't do any track work so maybe this is overkill. Any advice is appreciated.
    Gordon, NSW
    4,527
    Cookie, please follow the link that pugrambo posted. All your questions and answers will be in there. if you have any different questions, post it in that thread as it's a good thread to keep for brake upgrades on the 306.
    Any mechanic will be able to tell if your rotors are warped. If they are, then look into the DBAs which are awesome value compared to OEM. You will need to bed these rotors in (see the above thread) so use the OEM pads initially.
    If your rotors are fine, I'd still recommend sticking to OEM, as pads like Greenstuff are way too abrasive on the OEM rotor.
