EW Engine into a D8 406
    Fellow Frogger! aquinian's Avatar
    WA
    604
    Default EW Engine into a D8 406
    Hi All,
    Just wondering if it is possible to put the later EW10 engine (D9 406) into a XU10 engined 406 D8 sedan? If so, what would it involve? Would the wiring simply be a case of swapping the ecu & loom (same multiplugs?) or would it involve a lot cutting and connecting and tracing..
    If you are wondering why, the D8 has a blown gearbox and the AL4 expert said don't swap AL4s from non identical models. (Gear ratios, etc.)
    Michael
    Current: 406 Coupe, 504 Sedan
    Previous: 306XSi, 205GTi, 206Gti, 505 V6, 505 Wagon, 504 Sedan, 504 Wagon, 306Gti6, 306XT, 205Si, Citroen XM, Citroen Xantia
    1000+ Posts TroyO's Avatar
    2,513
    I thought the D8 auto was a ZF, not an AL4?
    1000+ Posts cav91's Avatar
    Romsey, VIC
    2,341
    Default Re: EW Engine into a D8 406
    The late d8 uses an al4
    Sent from my XT905 using aussiefrogs mobile app
    2017 Renault Koleos auto
    Banned Haakon's Avatar
    May 2002
    canberra...
    8,918
    D9 is multiplexed i think, so doubt it would be straightforward. You might be able to use pre-multiplex 206GTi computers and stuff...?
