205 gti arb
Results 1 to 16 of 16
Thread: 205 gti arb
    9,342
    Default 205 gti arb
    Jumped back into my S1 GTI today after a few weeks and noticed the way the rear tends to roll too much and make the front end push, some of this feeling is no doubt due to the manual steering but not all.
    This is not present in the Sis even though they have a small rear ARB and plenty of roll, I guess the front is set to achieve balance with the rear.
    Maybe rebuilding the beam will help, it does need it going by the clunks coming from there.
    Bigger rear ARB is probably the way to go, is there any way of doing this cheaply?
    I should know but probably wasn't paying attention when mentioned in various posts!
    Alternatively has anyone got an uprated rear bar for sale?
    Graham
    1000+ Posts djvu205's Avatar
    1,407
    I will be interested to see where this goes Graham. From what i know, there is a place in sydney that does it but best to rock up in person. i have a 23mm bar from a vts that i was looking to have re-splined but local quotes where around $400-$500
    23mm not an ideal size to recut due to the end plate sizes available 24mm would be ideal, i cant remember the exact details but this has some info
    Shorten and respline ARB
    9,342
    I think maybe try the welding method, after all what is the worst that can happen if it breaks?
    At least I can see what the difference is for no cost.
    Graham
    Quote Originally Posted by djvu205 View Post
    7,513
    I have a 21mm 306 ARB, a brand new 25mm 205 ARB and a pair of 306 arms that suit either. Make me an offer.
    9,342
    How would the 306 one fit a 205 width beam?
    7,513
    Default 205 gti arb
    Cut and weld. 306 arm one side, 205 the other. Or do it properly and re-spline.
    9,342
    That's what I was thinking, see previous post, but thought you were talking about trailing arms, sorry.
    1000+ Posts cam85's Avatar
    Nov 2003
    Bondi
    3,392
    respline it. Im having one done over the next month or so. I can ask to get 2 or 3 done at a time. Im using a 24mm from a 306 cut to my rear beam width. One of the best mods ive done, crazy stability and turn in..
    Cam
    94 205 Gti Classic #9
    91 205 Si
    87 205 GTi Race Car
    7,513
    ....or you could buy my 25mm bar & plates. Make me an offer. It needs to go.
    9,342
    A bit big for what I'm after Peter.
    I'd be happy with 21 mm.
    I might be slow... DRTDVL's Avatar
    Auckland
    1,288
    There isn't that much of a differance between the 24 and 25 (I have both) - if you don't want the hassle of cutting/welding or resplining get the 25mm bar.
    Nov 2003
    Bondi
    3,392
    Yea true. The 24 is stiff enough, the extra wont make a difference really as the chassis flexes/moves about too much anyway.
    Cam
    91 205 Si
    87 205 GTi Race Car
    Auckland
    1,288
    Graham, the 106 gti, saxo vts?, 306 s16/gti-6, all came with 24mm bars factory. Might be worth a try.
    9,342
    It is a lot bigger than standard though and really it isn't all that bad especially since taking some gear out of the back!
    Do you find the rear wheels come off the ground all the time?
    The GTi does this a lot more than the Si with only 3 mm bigger ARB, 16 to 19.
    Graham
    Quote Originally Posted by DRTDVL View Post
    Auckland
    1,288
    It's a lot bigger than the base model ones, and a decent size bigger than the gti's but only for 205/309's... The later performance models all ran the 24mm bar standard.
    The inside rear lifts a little more but it's already soo light there it's not funny - it's not really doing much.... You just need to be a little smoother to prevent liftoff oversteer. I found the stiffer bar really helped with grip out of the corners a lot also..
    I've had my 205 out on gravel with the 25mm bar and its been fine.
    Did you also do the si to gti torsion bars when you did the arb? Did you lower the rear to compensate for the increased spring rate? I know when I went from the 19 to 22mm torsion bars with the same shock bolt distances the car sits higher - making it more prone to roll in the rear...
    As cam said the 205 get so much better with the much stiffer rear end - you will need to adjust your driving style a little if your getting a lot of rear end movement.
    9,342
    The rally car (1.9 Si) is OK, it has 20mm rear bars and 160lb front springs with GTi ARB, subframe etc.. Also Bilstein challenge shocks. I don't know if there is any improvement in handling over the standard springs and Konis though and not as good on rough roads possibly due to not being able to use the front bump stops (inverted shocks) and having to rely on the internal Bilstein ones. I'm using standard ARbs, it is pretty taily on gravel, would be worse with a bigger rear ARB bar I would think.
    I had a very competitive run in an Autocross last weekend but then I was competitive there last year with the(Si) base model suspension just fitted with Koni yellows and it was easier to drive so I'm not sure where to go now.
    I'm doing an autocross this weekend in the standard Si road car to get some sort of a benchmark.
    Regarding the ARB discussion I'm just thinking it would be good to get a little better turn in on the GTi road car,which I don't use much, more of an investment/classic car, so hence the question about something like a 21mm rear ARB.
    Graham
