Hi Guys,
Has anyone had problems with diesel lately ?? For the last couple of months I've been filling up at a tiny petrol station out where my kids go to school ( old ... as in, they have to go out and read the pump to find out how much fuel I've put in).
About the same time I ended up with it running on 3cylinder due to a leaky injecter. I pull the injector apart (it was leaking at the screwed together joint in the middle). There was no evidence of a seal ... It still leaked when I re-assembled (
), so I re-assembled with thread tape fixing the problem. I've noticed over the last 6weeks the cars been quite stinky and has left small puddles of deisel on the ground whenever parked.... I just didn't want to know .... Why can't the heap of sh!t just run without problems for any length of time
Now I've been forced to look at it, it would start yesterday morning, I found no fuel in the line, so I replaced the fuel filter and primed the circuit. Then this morning it wouldn't start again (sigh). No fuel again, it's drained back to the tank. So I've just grabbed another 2nd hand hilux primer/filter assembly to fit tonight (there should be a one way valve in them to prevent the fuel returning to the tank).
I looked for the leak, and it appears the bloody pump is leaking around the gasket under it's top cover. Can I replace this without pulling the pump apart ?? It's a bosch mechanical pump.
Now that's 3 issues in the last couple of months ... age ?? Or am I getting dodgy deisel that is causing me issies
( just incase I'll never fill from that place again). How in the hell can a pump leak from a static seal between housings ?? How can a "sealess" injector start leaking
Something very strange going on here
