Hi all,
As some of you know, I'm in the process of shoe horning a factory 505 turbo (N9te) engine and BA10/5 gearbox into a 1970 504. After stripping out the engine bay and giving it a spruce-up, I'm ready to re install the front suspension.
I'm just wondering (my curiosity piqued by Peujohn's blog) about front strut options.
...You see, I have a nice set of front struts from a 1994 505 wagon STi kicking around, and I'm thinking they are probably a little stiffer (springs) which might be good for the bigger engine. In addition, I'm thinking (given what I've read in Peujohn's blog) that the stub axles may provide me with that desireable extra camber. I'm also thinking that they might provide better front calipers and rotors.
If I were to use these, would I still be able to use the standard 504 lower control arms and castor arms, or should I use the lower control arms and castor arms from the STi wagon? Or it it a bad idea alltogether?
Thoughts?
...just an idea...
Binky
Thoughts?
...just an idea...
Binky
