Good Morning,
In the interests of re-building the AF database of info and to update the progress on my 205, I will slowly add more info and photos. *cough* stolen from Isis's thread *cough*
Basic history:
It started life as a white 1.6 gti and was used as a press-car (i've got the original NZ Car mag where it was on the cover being thrown around a gravel quarry.) In 2002 the pervious owner - Mark Herbert -built the car for the 2002 Dunlop NZ Targa, and unfortunately didn't finish the race due to an accident. Mark repaired the car and then it's sat in his workshop waiting for the finishing touches to be done since then.
In 2008 went to see Mark to price up a rollcage for the 306, after 30 min of looking at the rollcage in the 205 to show me was he would do - i was sold - nice rollcage it was going to be... Mark then as i was walking out the door asked if i would like to buy the 205. I took 1 day for me to confirm that i could purchase the car - re: The GF approving that i spent the money on buying the car instead of a trip to the states, which as you can tell by reading this it was...
The car will be used for tarmac events until i can afford the undercar protection and gravel suspension - so i'm figuring a few years off... (note: 2 yrs later i'm still not able to afford it... hehe)
Engine:
Oil Cooler = 11 Row external (i think it's 11 row) Mocal
Engine = 405 MI16 4WD XU9J4
ECU = 405 MI16 4WD XU9J4 + Peter T Chip
Engine Mounts: Customised Factory Top mount, Aftermarket Uprated Lower Mount, factory gearbox mount
Sump = Customized Sump (Windage Tray, Increased Volume, Modified front)
Fuel Lines = moved into cabin, all braided lines
Oil Breather System = Custom
6Bar PTS Oil Pump Spring
Custom Heat Shield
Washer bottle = 309 rear bottle
Spec:
Dyno’ed at 128hp at the wheel at 7500rpm
Suspension:
Rear:
Cut down 306 S16 24mm anti-roll bar
Rebuilt rear beam.
Solid BakerBM mounts (group a)
Spax Adjustable shocks
Factory 1.9 GTI Torsion Bars
Assuming 205 trailing arms
Front:
Bilstien Adjustable Coilovers (unknown spring/spring rate - est 200/250lbs)
Adjustable Camber / Caster Plates
306 S16 Hubs with stud conversion
Exhaust
Custom 2.5 inch system.
Painted with Black High Temp paint
Gearbox / Drivetrain
306 S16 driveshaft – gear box input end
405 CV’s
205 middle and hub driveshaft ends
306 S16 BE3 (same ratios as MI16)
Kevlar Clutch
Quaife automatic torque biasing helical gear LSD
Upgraded linkages
Custom Quickshifter
Phosphor Bronze bushes
Brakes
Front:
Peugeot 307 XSP 283mm Disc / Calipers (rebuilt)
Peugeot 406 23.8mm Master Cylinder
Braided Lines
Middle:
Custom lines
Wilwood Adjustable Bias Valve
Hydraulic Handbrake
Rear:
Peugeot Rear discs on Series 3 beam
1.6 GTI front calipers using standard rear disc
Custom braided lines with banjo fittings caliper end
Body
Painted Silver
Satin Black painted trim, door handles, wing mirrors, slam panel, skuttle plate, gti badges
E30 Pre-Facelift lower lip – modified to fit
206 GTI rear wing – modified to fit
Sump Guard
Clear front indicators
405 arms wiper and 306 blades (larger sweep area)
205 “Automatic” Bonnet
Spotlights cut out of Bumper
Rear 1/4 windows = Lexan
Sideskirts have had jack mounts fabricated into them
3M High Temp Foil Tape along trans-tunnel
88 GTI wing mirrors (smoother and smaller then later gti mirrors)
Interior:
Battery behind co-driver’s seat
Water Temp, Oil Temp, Oil Pressure gauges
Electric Kill Switch
Interior Panels replaced with Carbon Fibre Panels
Chrome-Molly Roll Cage
Interior Completely stripped bar Roof Liner
Dash modified to fit rollcage
Seats = Racetech 4009w & Racetech 4000
Belts = Racetech (TRS) 3inch 6-point
Steering Wheel = Momo Race
Flooring = Checker Plate, sound deadening removed
Terraphone Professional Amplifier + 2 x touring head sets
Extended Steering Wheel Shaft
Wheels/tyres
4 x 15inch ROH Astrons
4 x 306 S16 rims
4 x 405 MI16
2 x 205 GTI “speedlines”
4 x DZ03 Semi Slicks
4 x Bridgestone G3 road tyres
5 x Dunlop D01J
4 x worn semi’s for trackday abuse
Thats all i can remember at the moment.
For the record, all mods have engineering certificates and it recently passed its roadworthy.
Basic history:
Engine:
Custom Heat Shield
Spec:
Suspension:
Rear:
Rebuilt rear beam.
Front:
Exhaust
405 CV’s
Kevlar Clutch
Upgraded linkages
Custom Quickshifter
Brakes
Front:
Braided Lines
Middle:
Custom lines
Hydraulic Handbrake
Rear:
Body
Painted Silver
Sump Guard
Interior:
Wheels/tyres
4 x 306 S16 rims
4 x 405 MI16
5 x Dunlop D01J
