Apart from disc brakes v's drum brakes, is an Si rear beam the same as a Gti?
Thanks.
Moo
...apart from torsion bars too!
...apart from brakes, roll bars, torsion bars - are the beams the same ?
Beam tube is slightly smaller in outside diameter.
The bushes are softer also.
Bearings and pivot arms the same.
If you use the si beam you will need the smaller clamp that goes from the beam forward opver the fuel tank.
