If all goes to plan my 504 will be converted to 505 GTI power over Summer. Paris Jansen is supplying the engine and gearbox, and the work will be done in his workshop with my "assistance". I don't know much about the GTI engine but believe this will be a fairly straightforward swap. I actually had a drive of a good leaded series 2 505 GTI a few weeks ago and was very very impressed with the way it went! Can't wait to have 96kW in the 504!
Paris will no doubt know what needs to be done in the conversion but I still want to start a discussion here about it. Any tips or suggestions welcome. I have a few ideas of my own too.
It seems the starter motors on these engines are hard to access, so I plan to put a rebuilt starter on to hopefully avoid having to remove it for a long while! I'm wondering about putting a lightened flywheel on.
The 504 already has a 505 radiator fitted, as well as an electric fan mounted on the back of the radiator. I guess I should be able to retain this setup with the 2.2?
I also need to decide what engine management to use. Megasquirt is the obvious and cheaper choice, but should I take the opportunity to fit something fancier? Paris mentioned Link as an option. If Megasquirt, where can it be purchased?
I wouldn't mind lining up Demannu's 504 with mine when they are both finished!
Please discuss.
Please discuss.
